Ohlins R&T with swift 8kg front and 9kg rear. I also have the stock 11/12kg springs that I will not be using.
The high speed damping is fixed by the shim stack. This is most likely what redwood adjusts to make it engage sooner.
Low speed is controlled by a needle valve and effects both compression and rebound. On the rear shock at about 25 clicks from stiff the low speed compression matches the stock damper. You can go softer than stock and still have the blow off for bigger hits.
Still working on this as I'm doing it in phases and documenting everything. I have a background in autoX and work on MTB suspensions in my free time.
This is a street setup. Comfort and control are the goals. keeping it off the bump stops maximizes both.
2023 Tesla Model Y Performance Stock 21in wheels and sub in the truck. Downsizing to 19's when I can afford it.
Swift 8/9kg. Front has 125mm and rear 110mm of spring travel before coil bind.
Rear damper length 605mm(-40), Stroke 120mm(-40), Bump stop 30mm. Total wheel travel is 138mm.
Spring total stroke is 83mm. 27mm of preload before coil bind.
Wheel to fender 410mm with 467mm at full droop (57mm). 41% sag, which is about perfect.
Rear shock uses 49mm of stroke.
You have 71mm of shock travel and 41mm of travel before the bump stop engages. 81mm of wheel compression travel.
Full bottom out gives stock 66mm of clearance.
Stock Rear: Shock 87%, spring 60% motion ratio of wheel travel.
Damper length 645mm, Stroke 160mm, Bump stop 60mm. Total wheel travel is 184mm.
Rear spring arm is 300mm to center of spring, 435mm to shock bolt and 500mm to wheel carrier.
Spring total stroke is 110mm.
Wheel to fender 405mm with 505mm at full droop (100mm).
Rear shock uses 87mm of stroke for 87% motion ratio.
You have 73mm of shock travel and 13mm of travel before the bump stop engages. 84mm of wheel compression travel.
Full bottom out gives 66mm of clearance.
