Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 42
Thread: Stuck charge cord
  1. #11
    SSL #180
    Mar 2009
    Minnesota
    Quote Originally Posted by JRP3 View Post
    I'd guess that didn't work in this case since the service tech had to take it apart.
    The operator also tried to free the plug by sliding something in there. Don't know what order things happened, but if they were unfamiliar with the car I could see something like this:
    1) car is plugged in and locked
    2) reviewer goes to unplug cable with unlocking car
    3) cable won't release because car is locked
    4) not realizing this, he pulls harder, and even tries to jimmy the cable
    5) this damages the lock mechanism requiring a service call
    Now, that is pure speculation. I haven't seen any issues like this and the only time our charge cable was 'stuck' was because the door was locked
  2. #12
    Sig P85
    Nov 2012
    Colorado
    I charge with a J1772 and the adapter. I've noticed that when I disconnect the J1772, the locking mechanism holding the adapter in the charge port unlocks. Unless I pull out the adapter within a few seconds, the lock engages again and the adapter is stuck. Unlocking the doors doesn't release; I have to access the touchscreen to "open the charging port", which once again unlocks the adapter.
    The most worrisome thing is that simply disconnecting the J1772 causes the car to unlock the charging port (and adapter), even when you walk up to a locked car without the key fob. Be careful at public charging stations--I'm sure the J1772 adapter isn't cheap.
  3. #13
    Member Ceilidh's Avatar
    Oct 2012
    Los Altos (Silicon Valley), CA
    Quote Originally Posted by tezco View Post
    Having watched cinergy's (sp?) charging video, it would seem that having the j1772 turn off and then pulling out the plug without pushing the button that disconnects it from the adapter is the better way to go. Then you don't have to mess with removing the adapter by itself. You can just pull the plug off with the adapter still attached, then remove the adapter from the J1772 plug, which is easier, or so it would seem from the video.
    Don't have my car yet though, so this is all second hand. You can watch his video on youtube here:
    Tesla Model S J1772 Charging - YouTube
    Cheers
    Grey, Grey Leather, Piano Black, 60 kWh battery, Air Suspension, Standard Audio, Pano Roof, Tech package, Jump Seats, Supercharging, Twin Chargers, 19" Wheels
    P 912 / VIN 5YJSA1DG5DFP03541 Factory delivery 1/26/13
  4. #14
    Model S VIN P01536 Robert.Boston's Avatar
    Oct 2011
    Boston MA, USA
    The sequence that my DS recommended is:
    1. From the center console Charging screen, touch the Stop Charging button.
    2. From the center console Controls screen, touch the Charge Port button in the unlock section.
    3. Pull the charging cable (still connected to the adapter) out of the car's charge port.
    4. Remove your adapter from the J1772 cable.
    5. Close the charge port door.
    6. Hang up the J1772 cable on the charger.
    7. Double-check that you've got your adapter!
  5. #15
    Sig P85
    Nov 2012
    Colorado
    Quote Originally Posted by Ceilidh View Post
    My J1772 adapter is very hard to pull out of the charger port--takes two hands. If I pulled out using the plastic hook on my J1772, I'd probably break that hook off at some point. Main problem I'm worried about; however, is that the charge port unlocks for anyone on the street.
  6. #16
    Senior Member JRP3's Avatar
    Aug 2007
    Central New York
    I wonder if a thin coating of silicone grease might be helpful?
  7. #17
    Member Vger's Avatar
    Apr 2009
    Salt Spring Island, BC, Canada
    Silicon grease might attract dirt. I was thinking to try what us sailors use to keep parts on our boats sliding: McLube Sailkote. It is a dry PTFE lubricant, which leaves only a microscopic dry and very slippery film.
    "Constraints are gifts to creative people."
    Roadster 2.0 #905 | Model S Signature Performance #2001
    PLEASE NOTE: Posts are the copyrighted intellectual property of the author, and are intended as part of a conversation within this forum. My words may NOT be quoted outside this forum, without my expressed consent.
  8. #18
    Aug 2007
    Central New York
    Yeah that sounds better. I'd cover any contacts when applying it.
  9. #19
    Sig P85
    Nov 2012
    Colorado
    Quote Originally Posted by Vger View Post
    Yes, I might spray some silicone spray on the end. I'll have to tape off the contacts and the other end that I grab hold of; otherwise it will be too slippery to pull out.
  10. #20
    Senior Member cinergi's Avatar
    Sep 2010
    South Boston
    Blog Entries
    There's a new version of the J1772 adapter that's not has hard to remove. Ask your service manager about it.
    SOLD | Roadster 2.5 #1077 | Very Orange | Forged Wheels | Electronics Package
    Model S #SSL146 / VIN #246 | Signature Red | Black Interior with CF Accents | 21" Silver Wheels | Panoramic Sunroof | Performance
    http://fearlessbit.com/
  1. Mennekes stuck in the station
    By Mitrovic in forum Netherlands, Belgium, Germany, Austria, Switzerland
    Last Post: 08-02-2012, 07:10 AM
  2. Extention cord
    By Johan in forum Charging Standards and Infrastructure
    Last Post: 07-08-2012, 03:00 AM
  3. Replies: 0
    Last Post: 06-15-2011, 04:29 PM
  4. Replies: 28
    Last Post: 02-03-2010, 01:25 AM
