The old less (parts, effort, etc) is more (affordable) route, rather than the less (inefficient, etc) is more (affordable) routeYeah, and the big disadvantage of prismatic cells is the lack of protection against swelling - which all cell chemistries are exposed to.
Cylindrical cells have strong protection against swelling, in form of a strong metallic, cylindrical casing.
Prismatic and pouch cells, not so much:
Most non-Tesla car manufacturers are using pouch or prismatic cells not because it's superior, but because they don't know how to make battery packs with cylindrical cells economically.
At this point, we can all consider Ford to be full of BS about everything related to the Mach-E. Profitable starting on the first car......with no prior mass production EV pipeline, supply chain and logistics, battery cells and modules....shall I go on? I can't take them even remotely serious after that statement
Just for reference here are the latest Ford numbers first nine months of 2019.At this point, we can all consider Ford to be full of BS about everything related to the Mach-E. Profitable starting on the first car......with no prior mass production EV pipeline, supply chain and logistics, battery cells and modules....shall I go on? I can't take them even remotely serious after that statement
Assuming the Mach E specs are truthful, which probably got leaked inadvertently. If they hadn't gotten leaked then the suspiciously Tesla-alike specs would normally not have been in news after the unveil event today, assuming Ford partners with Tesla.
Anyway, given that there's only a few hours until the unveil, this post might age incredibly poorly.
Wrong on most points.
Prismatic cells (or rather packaging) wont change those properties of the batteries. Other car makers are using NMC type cell material which is safer but more expensive. Tesla uses NCA which is cheaper, has slightly higher energy density but not as safe (lower thermal runaway temperature).
NMC lasts longer than NCA. So wrong on that point as well.
Before I start a very long post on exactly how I think Tesla is winning in EV powertrain costs, just a reminder how significant Tesla’s $4-6k cost advantage is. ICE OEMs normally make around $1k EBIT per car, while luxury cars can be $2-3k. If an ICE OEM had the same cost advantage vs other ICE OEMs for ICE cars their profit per car would be 5x higher. And Tesla’s $4-6k cost advantage here is on powertrain alone – they have other significant savings including from not advertising, not using dealerships, using an online first sales model, higher vertical integration of non-powertrain auto manufacturing and higher non-powertrain manufacturing innovation.
Relative to the Chevy Bolt I estimate Tesla Model 3’s $4.1k powertrain cost advantage comes from roughly: 1) $1.6k lower cell costs, 2) $1.4k lower pack (non cell) costs 3) $1.2k better wheel to wheel efficiency (mostly this), weight & drag. On top of this Tesla’s powertrain performance, longevity and likely safety advantage all come for free.
How does Tesla beat ICE OEMs efforts in each of these categories?
Cheaper battery cells.
Tesla’s three key advantages are 1) ability to use stripped back simplified cylindrical cells, 2) ability to safely use the in principle more dangerous NCA chemistry and 3) economies of scale (including standardized cell size unlike prismatic cell sizes which vary with battery pack design).
The core of 1 & 2 is that Tesla is able to use simplified cylindrical cells (with no safety systems) and NCA chemistry because it has far superior battery management software (including fleet learning benefit) and hardware – it shifts cell costs into battery pack IP (and no ICE OEMs are even attempting to catch up on this path).
Cylindrical battery cells
Advantages:
Disadvantages :
- Cheaper to manufacture.
- Has the least components and simplest manufacturing process (8 components vs up to 30 for prismatic cells which are now mostly being adopted by the industry).
- Cylindrical is the most mature technology and has the most automated manufacturing process with highest utilization rates in manufacturing steps.
- Tesla’s NCA cylindrical cells have by far the highest volumetric energy density, I think in part due to tighter cathode winding in cylindrical structures. This should reduce pack size and hence pack (non cell) weight.
- One cell design can fit multiple different battery packs and vehicle programs. Pouch/Prismatic generally have to be designed differently for each program so get much less economies of scale. For example CATL makes 34 different shapes of cell while BYD makes 10.
- Cylindrical cells generally need less safety specific components, but Tesla’s cells are able to strip these back further - Tesla's cells lack a CID (vent ) and a positive temperature coefficient device. They can do this in part due to the pack design and software.
- Mechanical stability against internal swelling.
- Smaller cells can allow better thermal management.
- The winding process can be done faster than stacking for other cell types, they can also be wound tighter.
- Limitation in cell size means a huge number of cells per car which makes module assembly much more difficult and makes cell balancing much more difficult. Model 3 has c.4000 cells vs c.300 pouch cells in the Bolt.
- More cells per car also means more chance for something to go wrong.
- Cylindrical cells have lower gravimetric energy density (for equal chemistry) I think mostly because smaller cylindrical cells need more housing material. This is largely compensated because it is easier to use higher cathode energy density chemistries in cylindrical cells.
- Cell testing is more expensive because more cells need to be connected and tested.
Tesla’s NCA chemistry has the highest nickel cathode content and the highest cathode energy density of any EV. It has much less cobalt than NCM designs which reduces raw material prices and reduces supply risk. Its disadvantage is the chemistry is less stable relative to lower Nickel content/lower cathode energy density cells – this is another reason Tesla uses cylindrical cells – the smaller canned cylindrical format helps limit this instability.
I think Tesla's current NCA cathode chemistry is Nickel 93% Cobalt 5% and Aluminium 2%. This compares to most common NMC 532 at 50% Nickel, 30% Manganese and 20% Cobalt.
The rest of the industry is starting to transition to higher Nickel NMC 811 (now c.7% of China cathode production) which is closer to NCA. However this chemistry will face increased manufacturing costs and increased safety challenges, particularly given the industry does not have the battery pack expertise to use smaller cylindrical cells which limit the chemical instability.
Is anyone copying Tesla’s cell approach?
No Auto OEM is trying currently. For example in China in July just 5% of battery KWh in EVs was cylindrical cells (and this was still mostly 18650) and NCA is only around 3% of total cells. Model 3 cells are 257WH/kg. CATL’s highest energy density cell is 236WH/kg and BYD doesn’t have any >220WH/kg. They both largely make prismatic cells.
Some startups such as Rivian say they will be using cylindrical cells, but exactly what chemistry they use and whether they use the same extremely stripped back cell design as Tesla is unclear.
Cheaper battery packs
Tesla’s battery pack strategy is very similar to its Autopilot strategy. It is all about vertical integration, software and fleet learning. Tesla’s pack costs benefit from a lean and high tech design as well as from the high volumetric energy density of its cells, but also because it has shifted cell/pack hardware complexity into better (likely neural net based) software. The Munro teardown found Model 3 pack cost at $30/kWh, half of the $60/kWh in the Chevy Bolt, despite Model 3 pack’s ability to use higher energy density cathode chemistries and much simpler and cheaper battery cell designs.
Tesla is the only automaker that can continuously collect data from its customer fleet, it is also the only automaker that has designed its own software, semiconductors and other pack components in-house (normally these are outsourced to multiple suppliers). For the battery it can collect information on driving style, charging, battery temperature, battery capacity changes, voltage, degradation etc. This statistical data is fed into Tesla’s BMS to precisely manage tiny differences in each cylindrical cell’s performances and provide equilibrium for the overall system. Tesla’s BMS software use multiple in-house designed ASIC chips called batman and robin for cell balancing. I think it is highly likely Tesla’s BMS is neural net based with data fed into a neural net to optimize management and balancing across the 4,000+ cells.
The BMS software delivers:
Together with the better software, Tesla limits (as far as we know eliminates) the dangers of high Nickel cathodes by using pack materials with low heat conductivity and using inbuilt thermometers.
- High useable capacity of the battery cells.
- High and safe charge rates.
- High safety despite the less stable high energy density chemistry. (The software limits flammability risks - it ensures temperature is not allowed to rise and prevents metals deposits forming)
- High safety despite simplified cells without in-built safety features.
- Limited degradation and long life (in miles) of Tesla’s batteries relative to the competition. This benefits from Tesla’s precise cell balancing.
- Resilience to a certain failure/error rate of cells (many competitor’s designs require perfection to operate safely or at all).
Moving so much of the cell/pack tech/management into software rather than hardware means Tesla can use the same hardware designs for multiple different products - semi/storage/performance cars/pickup/Model 3 etc, giving better economies of scale.
Tesla’s reliance on fleet learning, vertical integration and software as the core of its battery strategy gives it a huge advantage against ICE OEMs and as far as I know Tesla is now so far ahead nobody is even trying to copy their approach. ICE OEMs do not have the vertical integration to design a harmonized overall system. They do not have ability to collect data from their fleet. They do not have software or AI expertise to move to a software first approach. Unlike Tesla they do not have 10 years of data to feed into their system to enable use of cheaper cells and higher risks chemistries. Given the bad publicity surrounding EV fires, it is extremely high risk to roll out a new high risk battery chemistry/pack design without first having the fleet data to optimize the software to ensure safety – I just think it is extremely difficult for anyone to risk following Tesla at this stage. As Tesla bears UBS write: “Despite Panasonic's cost advantage we expect to see limited adoption by other OEMs. A sophisticated battery management system (Tesla produces in-house) is required for the format and we do not think this is easily replicable.”
Better battery to wheel efficiency
All Tesla cars again significantly beat all the competition on this key metric. The cost savings from better powertrain efficiency can easily be higher than savings on cheaper battery cells. More efficiency means lower battery size for the same range which means lower battery costs – this can be worth as much as $4k relative to cars such as the I-Pace.Better weight (both battery pack capacity/kg and motor power/kg)
Tesla wins here for 2 main reasons: 1) It has the most experience and best engineers with the best hardware designs and 2) It has the most vertical integration and best software talent which allows design of a harmonious powertrain.
Some specific hardware breakthroughs Tesla has made include the use of a high efficiency silicon carbide inverter, a breakthrough permanent magnet motor design (willing to pivot from its previous expertise in induction motors), high tech cooling design, reduced cabling and combination of multiple hardware components into the same housing with a modular and compact design.
On the software side again, the vertical integration and fleet learning across the entire EV powertrain has allowed continuous improvements and efficiencies. Overall, including battery and other powertrain, software has driven around half of the 40% improvement in Tesla’s powertrain over the past 5-6 years.
Tesla’s battery pack capacity/kg beats the competition I think in part due to the better volumetric energy density of its cells – which requires less pack casing. E-tron and EQC battery packs are about 2kg/kWh heavier than Model 3, which can add up to around 200kg on the car which has a negative impact on range, acceleration and handling.
Model 3 also has the best power-to-weight ratio of its electric drive unit (motor and gearbox) of any electric vehicle in the market.
Better drag coefficients.
Model 3's drag coefficient is just 0.23 which is the best of all cars in its segment. Tesla obviously has extremely smart engineers and designers working to minimise drag co-efficient while maintaining aesthetics. ICE OEMs are often handicapped here, partially because their vehicles and brand has a distinctive “look” which they are trying to maintain despite the shift to EVs. ICE OEMs are also handicapped because many have decided to build flexible platforms (to avoid properly committing to EVs) which can be used for ICEs, EVs or PHEVs, rather than being designed specifically towards EVs.
Dahn bought the material from another party and tested it. Wrote an article about it. It's not related to Tesla.
Unfortunately for Ford, this mustang variant will only drive Tesla sales.meh, the first car is a year away from delivery and there are plenty of battery factories offering cells coming online between now and then who will be able to supply the initial low volume ford needs. And the “first car” will be the premium models starting at $50k+ for the low range model, so Ford should be able to eek at least a penny profit from those early cars.
however there is a big difference between a just above break even car selling at $50k+ and a Tesla selling in the $40ks with 20%+ gross margins (which includes premium features like a glass roof & AP as standard)
I read about over-the-air updates but it doesn't say it is FREE, unlike Tesla.
I thought Tesla had an infinite number of service locations?
Will ford come to my job to service my car?
Tesla does!
I don’t trust traditional auto companies
I trust Tesla
My car has not needed any service
Charging is up to 150 kW (on the website).
The most I like the idea of no handles for the doors.
Does Tesla bring a lift to your job?
Unfortunately, many Tesla owners need to take their cars to actual service centers where waits can be very long.
Most of the car buying public trust traditional auto companies more than Tesla.
That's not the issue. The I-Pace "has OTA updates". Yet it still needed to be brought in to dealerships to fix the exact same braking issue that Tesla fixed OTA. Why? Because Tesla is the only automaker that operates on a unified software stack. E.g. while "some" components of the I-Pace are able to be updated OTA, overall functions are spread out among a large number of discrete boxes made by various OEMs scattered throughout the vehicle, and most of them cannot be updated OTA.
Volkswagen is the only old-school automaker that I'm aware of that's officially embarked on a campaign to create a unified software stack, although I imagine that others might have projects in the works behind the scenes. But it's a huge undertaking. Tesla has been working on theirs since their inception.
Automotive revenue: 106.928 Bn
Ford Credit revenue: 9.231Bn
Mobility revenue: 26m
Net Income: 1.756 Bn
Net income excluding Ford Credit: (31m)
At this point Ford is a financial services company making hardware at cost, that its leasing arm can profit on.
To give you an impression how good Ford is at software ... Go to 4min27sec
This is probably very helpful for those who can understand what the person is saying.
Here we go, another SUV/Crossover and they raped the Mustang name. Good job Ford.
