Model Y Performance 21" Tires - Larger, More Comfortable Fitment Details and Experience - Michelin AS4's (With Photos)
Raurele,
Do you bring the MYP to Tesla for alignment with your tire setup? Thank you for your feedback. I am in the South Bay as well. I probably bring my MYP to Sunnyvale or Palo Alto.
yes. I was told specifically by a tesla engineer to do so. just a single alignment. in includes a camber adjustment
generally, once you go off stock with suspension parts, spacers, wide tires, best to not goto Tesla
Its tires. people change tires sizes all the time. Tesla will do the alignment.
Reactions: kpanda17
I recently had to replace my 2022 MYP OEM Michelin All Season 4's and after a lot of research, and tire hunting, wanted to share my experience and the direction I went. Valuable information for those close to ordering new tires. I just drive 2000 miles through Santa Cruz, San Jose, Sacramento, and did a weekend in Tahoe, driving on many dirt roads and rough roads.
First off, I will never go with another set of tires after having these. I made it to 37,000 miles with 3/32 left on all 4 tires. they wore evenly. Their performance in heavy rain and even 6" of snow was unbelievable. Ive had multiple cars with Pirellis, and always stuck with them, but was not happy with the miles I got out of them, and the thought of getting 27,000 miles on them with an EV just sounds terrible considering the price.
The Tires
I went up in size with width, and sidewall.
Stock/OEM for the MYP is:
Front: 255/35/21
Rear: 275/35/21
The tires I chose are:
Front: 265/40/21
Rear: 295/40/21
Fitment
Front wheels fully turned, there's still >1" to the inner tire well. So no rubbing at all, even with quick turns into parking lots (Where you would probably get rubbing the most)
Rear wheels haven't rubbed on any large bumps. I even tried to get them to rub. nothing.
The main bonus functionality wise is that the tires extend farther out than the rims. not much, but they do.
Look
The difference is huge. Pictures don't do it justice. When I see other MYP's now, the OEM tires look stretched and the amount of room in the tire well looks like a mistake. maybe not on the MYLR, but for a performance, the larger sidewall REALLY looks great. It creates the illusion that your car is lowered, but its actually ~1.5" higher clearance
It truly looks performance even though It can handle bumpy roads and "All Season" conditions even better.
Before:
After:
Efficiency
This part was really interesting.
Bigger tires have a higher rolling resistance than smaller tires which means they require more resistance and effort to get them rolling. However, if you do a lot of freeway driving at high speeds, larger tires can help increase your vehicle's efficiency.
So, days I drive a lot in the city with lots of stop and go, I get about 7% less range. but when I do a lot of freeway driving, I get about 7% better range.
I drive 150-350 miles a day, and have found zero difference in range because I do a wide range of road types. I really thought I'd lose range.
Feel
WOW, what a difference. Sure the suspension is still stiff, but I feel a LOT less of the small imperfections of the roads I drive on every day. even my girlfriend said she noticed it before I got to point it out. Speed bumps and things feel much better and not like im driving over a 2"x4". This is my favorite part of these tires functionality wise. Cant describe it.
There is no foam in the tires, but they are STILL quieter than the OEM with the foam. that stuffs a gimmick.
Things To Be Aware Of
Speedometer: It is not going to be accurate. Due to the larger diameter, it is off. I called Tesla, and talked to 2 different service centers, and there is nothing they can do about it. This seems like something Tesla overlooked. The only thing you can change is your rim size in your cars settings, but not the diameter...
So, when my car says im going 70MPH, im actually going 74MPH.
says 25, im going 26.5
says 40, im going 43
says 65, im going 68.5
says 85 (for AP max) im going 90.
This is something that as long as you keep in mind, it doesnt matter. I just changed my cruise control settings so it doesn't add 5MPH anymore. I chose 7% increase and it's fine.
I dont know if it's the new beta version, or that the car thinks its going slower than it is, but ive noticed that on AP/FSDbeta, it is taking turns a little wider and sometimes touches the lines on the outer edge of the turn if im going above 50mph. I'm pretty sure it's the speed issue.
This really needs to be able to be corrected by the user in the settings. sometimes switching brands can add .5in of diameter even if the tire is the same "size".
Conclusion:
Go Bigger! the OEM tires are actually stretched on your Uberturbines. they are meant for wider tires but Tesla went smaller for efficiency reasons, which in the end, didn't matter. Finding the OEM sizes of these wonderful tires is basically impossible. They are on a national backorder right now which is why I went for a different size in the first place. These tires arent cheap, but they ARE worth every penny.
American tire warned me that they weren't OEM sizes, and I told them I know for a fact they will fit and they had no problem installing them.
Here's some more pictures just for fun. These are some CHONKY tires. Thicc with 2 "C"s. tiny American tire man for reference.
View attachment 853304View attachment 853305
Rear 21’ tire wear so much depends how hard or easy you accelerate from a stop…
I drive very hard, specially if anyone is up for a challenge 😲🤣😂 I strictly purchased the YP for the performance and I enjoy every moment.. My rear tires do take a beating but I don’t mind; I had the rear tires replaced at 27K miles 😃🤷🏻‍♂️
Reactions: kpanda17
I drive like a madman. I got the performance for the same reason. not sure where in Cali you live, but I drive Santa Cruz to San Jose every day on the 17, fast. it's brutal on tires. still got 32k miles on the first set, and 35k miles on the second, the AS4s will last you!
Reactions: Msicario
You’re the NoCal demon and I’m the SoCal one🤣😂 So much fun, specially not doing any maintenance or burning high octane gasoline 👍🏻
If you replace all your tires with ones that are larger it should have no effect on your alignment. The suspension doesn't care about tire size.
I always have an alignment with new tires to maximize the life, but if you just had an alignment with new tires swapping them to other good condition tires should have no effect.
I’ve recently upgraded my MYRWD set up from oem 19x255x45 to front 21x265x40 and rear 21x285x40. Rims were self designed and produced in China and tires are from Hankook.
I’ve experienced zero rubbing and the ride comfort has improved as well. However, i am not thrilled about the stance and would like to drop her about 1.5” in the front and 1” for the rear. With that said, I’m concerned about the tires rubbing and hitting the inner fenders while driving as the new set up is wider and will be lower.
Does anyone have experience in this? Any issues or concerns? Would appreciate a feedback if any. Thanks!
If you put larger diameter tires on your car, the camber will be off. That’s just math…
tires that are wider or taller than original equipment tires stretch the suspension slightly and cause changes in camber and caster angles
This entire post makes no sense at all. Alignment is measured with heads mounted to the wheels. The machine doesn't care what tires are installed, nor can it tell.
MYP has negative camber in the rear, like most sports cars, by design
This provides for performance handling on curves but inner tire wear increases
No free rides
Wider tires make the wear worse but handling improves even more
By installing MPP brand adjustable rear camber arms, we can hinder the performance by straightening vertically the rear tires while minimizing wear, but again if performance is rhe pure goal not what you want to do
If decreased wear is rhe goal, the adj arms will help
It’s a balance
No free rides
YMMV
Lowing the car on springs has zero effect on the max compression travel. The suspension will bottom out in the exact same place.
You can get a little bit of extra compression in the rear with coilovers but then you need to test your combo by fully compressing the suspension without a spring installed.
Model y and 3 both are already limited in compression travel. Lowering it will decrease ride comfort and always engage the bump stops.
Reactions: davidc18
thanks! But i'm reading from few posts here that the ride comfort is basically the same. Suppose its just preference and feel.
