BigTonyTones
Is it just a keyfob upgrade or does something in the car also have to be updated in order for the newer key fobs to properly work?
This is a different attack than the key relay attack. Reley attack is about extending the signal of the key fob (can be used once, when in proximity of key). This attack copies the cryptographic key of the fob. Can thenafter be used as a normal key!The Wired article does its best to be sensational, but the whole attack is the already well-known relay attack against 'passive entry' which is optionally available for the Model S:
"Aside from the PIN, Tesla also allows Model S owners to disable passive entry for its key fobs, meaning drivers would have to push a button on the fob to unlock the car. That would also stymie the KU Leuven attack".
So nothing new here - as far as I can read.
Good news is indeed that this attack won't work when " Passive entry" has been disabled.
I think there are 2 different considerations here:Is it 100% sure this attack will not work with passive entry disabled?
@brkaus
Cryp·tomer on Twitter
Let's make this clear: disabling passive keyless entry on your Tesla *will not* prevent our attack. If you want to secure your car you must enable the 'pin to drive' option.
Times might have changed but when I replaced my P85 fob (hot tub incident), they had to replace both (or so I was told) and only the new keys would work (I was told the car only supports 2 fobs active).just make sure your old fobs are removed / deactivated from the car once you have the new ones
Were they going to charge you for the new fobs? If so, how much?Went in today for my service appointment to address this and they were aware of the new keys. Unfortunately they were unable to get my car to recognize them and they suspect it might be a future software update before these can be replaced.
One article I saw listed the cost as $150 per key but I can't confirm till I have an invoice.
@oaito
My impression from their statement is that disabling passive entry prevents relay attack but doesn't prevent fob cloning. But of course I may be wrong.
Back in "communist" time, we (our parents) used to "secure" the cars by removing spark plug cable. Maybe it's time to start securing "smart" cars by pulling out some relay or so...
That's basically what PIN to drive does.
@TaoJones taps don’t do much to the MCU. I wouldn’t worry about that.
Did they look it up based on the part number in the catalog? I cannot find the thread at the moment where someone said they had them.
I’ve decided I’m not going to worry about it. Fob cloning isn’t popular here (yet), the car can be tracked, and I have insurance.
Either way, old or new fob, the relay attack is possible.
