brkaus
Yes. They replace at annual service, easy to do yourself. I replaced proactively at 18 months. It will warn you when low. Not sure if the warning trigger is accurate.Speaking of key fobs, is the battery user replaceable and how long are they supposed to last?
Suggestion - read the manual on what to do if the battery is dead. For extra credit, try it when you remove the battery to put in the new one. The model S uses a CR2032.
New part number for the 80-bit fob is 1455940-00-A
