bonnie
I play a nice person on twitter.
I am getting the winter studded snow tires and giving my Model S a test this winter. This is my Pagosa Springs Driveway in the winter. We will see.
My money's on you.
Winter in Oslo in the best case means roads covered by a thin layer of brown, slippery mixture of mud and road salt. More commonly half-frozen slush will pack the wheel wells full and freeze solid overnight. We get new snow from time to time, occasionally lots of it. Most of the winter, cornering grip is but a fond summer memory, and you're happy as long as you can keep the ice out of your wheel wells so the springs can move more than 5 cm.
Is it possible to downsize to 235/55-R17 for winter use? That would save me about USD 160 to 175 per tire, and narrower, taller tires have less tendency to plane on snow and slush too.
Yesterday I paid US$268 per tire for the Nokian Hakka Rs in 245/45 R19. I hope they are great for the snow.
Sadly I am switching out from my 21 inch wheels after I drive my car around the block one time. I won't really be able to compare the two until spring. How can they cost 160 more per tire?
Jerry, I meant to respond to eledille who said he could save 160 per tire. That would make the 17 inch tires only $108 each. I doubt they are that cheap.
You're describing conditions that sound very much like parts of Ontario, Canada where I live. I remember a couple of years ago having to find a heated garage (my attached garage at home was still below freezing) to let my car sit and melt the ice out of the wheels and wheel wells. The ice inside the rims caused terrible vibrations and the build-up in the wheel wells restricted my steering to a few degrees left or right! The stuff was solid, too. No way to chip it out by hand.
Narrower tires do provide better winter traction. I use slightly narrower winter tires myself, but try to keep the same overall diameter. There are on-line tools that'll help you pick equivalents.
There will likely be a brake clearance problem on 17" wheels. 18" might fit. Your quite right that the narrower tires are far better for winter conditions.
Yesterday I paid US$268 per tire for the Nokian Hakka Rs in 245/45 R19. I hope they are great for the snow. Sadly I am switching out from my 21 inch wheels after I drive my car around the block one time. I won't really be able to compare the two until spring. How can they cost 160 more per tire?
Are the Pirelli tires any good? I was trying to get the Nokian R tires for my parents in Indiana but it is easier for them to have Tesla just deliver their tire package with the Pirelli winter tires.
(snip)
They're the best in the most-used tire test in Norway this year. Michelin, Dunlop, Goodyear and Continental also have very good tires, but only Michelin X-Ice can match Nokian for rolling resistance, which is important for EVs.
The test is here, score table here. Translation: Piggdekk = studded tires, piggfrie dekk = studless tires, is = ice, snø = snow, våt = wet, tørr = dry, økonomi = economy, bremsing = breaking, kjøreegenskaper = handling, retningsstabilitet = directional stability, støy = noise, rullemotstand = rolling resistance. The test is conducted by pro tire testers at Test World in Finland. Motor (Norway), Aftonbladet (Sweden), Auto Motor & Sport Sweden, Tekniikan Mailma (Finland) and Autorevuei (Russia) pay for the test, choose the tires and decide which characteristics will be tested. I mostly ignore the dry asphalt category and place extra weight on braking and handling on snow and ice, plus rolling resistance. That makes Nokian the winner, closely followed by Michelin, then Conti.
Congratulations on that price... If I could get them at that price I wouldn't worry that much, even though I would still want them narrower. Just look at some winter rally pictures. They're not using those cartwheels to save money! But paying 60% more for a poorer tire is horrible. The high cost difference is due to high Norwegian prices. The best I can find for Hakka R in 245/45-R19 is NOK 2700, the best for 235/55-R17 is NOK 1700. 1 USD = 5.75 NOK, so the difference is about 175. I thought that importing tires would not make sense, then I have to pay 25% VAT + shipping. I'll have to check it out, though. I can buy in Sweden and pick them up, but it seems they're almost as expensive there.
They're not bad, slightly behind the best on snow and ice. But they have more rolling resistance. Check out the test above, then you can decide for yourself which characteristics will be most important to your parents and modify the weighting.
Is in important to get Tesla's rims, or do we have other options that are as good?
In preperation for winter, today I changed my 21" gray rims/tires for the 19" silver rims/tires. The car looks totally generic. I miss the look/style of the 21" gray turbine rims. I really wish Tesla would make a set of the 19" gray turbine rims.
Here are photos of the 19" rims and brake caliper housings on my S, front and rear. The front calipers are larger: there is much less than an inch of clearance on the front wheels, and I think still not quite an of an inch of clearance on the rears. It's hard to measure exactly.
Probably not, but still not proven, one way or the other. 18" wheels look promising, though, at least on the rears.
