Moving consumption away from the peak is good; but if so much usage shifts that the deemed peak hour-period no longer contains the peak, then you haven't solved the problem, merely shifted it (and inconvenienced a bunch of people in so doing).
Err, no. Current retail rates average the cost-to-serve across all members of a rate class. If you could suss out the actual cost to serve each individual customer, you would find that some customers are paying less than their full cost, while others are paying more. That is, the cheap-to-serve customers are subsidizing the expensive-to-serve customers. When TOU rates are introduced, however, this cross-subsidies begins to unravel: the actual load profiles reveal who is expensive to serve, and who is cheap. Therefore, once TOU rates are introduced, approximately half of all customers will see higher bills, while another ~half will see a rate drop. TANNSTAAFL.
If TOU is optional, however, rational people will only choose TOU if their usage pattern results in a savings. This self-sorting ought to lead to an increase in the flat (non-TOU) rate, because the profile of the average use of people in that rate class is now more costly to serve. Until the utility applies for and receives that higher rate, however, it will be losing money. Which may be one reason why utilities aren't racing to introduce TOU rates.
Depends on how wide your peak hour period runs. Central Maine Power's "peak period" in the afternoon is 2pm to 6pm; it's easy to imagine how a lot of demand could shift into the 6pm-7pm slot.
Just look at the CAISO Today's Outlook page. Pretty clear how usage peaks in California.Depends on how wide your peak hour period runs. Central Maine Power's "peak period" in the afternoon is 2pm to 6pm; it's easy to imagine how a lot of demand could shift into the 6pm-7pm slot.
Broad rise centered around 12pm and a sharp rise between 6-7pm with minimum demand between 1-5am.
This is typical for winter months. In the summer months when it's warm, the primary peak is in mid-late afternoon due to air conditioning use. The 6-7pm peak is not as significant. You can use the Renewables Watch page to see historical data.
No, peak shifting is when enough appliances shift their usage to create just as high of a power usage, hence a peak, but at a new time that is off peak from the TOU stand point. Then you have the same problem as before but people now pay less to cause it. That leaves you actually worse off than before. Another problem with TOU pricing that most people don't consider is load synchronization. Most of the thermostats and water heater usage is pretty uniformly distributed through time during peak hours. Having a TOU gets everyone to delay using until right after the peak time ends and then they all turn on. This synchronizes the heating cycles and can result in a higher peak than before, and an oscillatory load shape afterwards. It's a shame I can't attach a .pdf to this post or I would upload the module from the smart grid class on demand response and TOU pricing so you could get a better idea of all of the issues surrounding this.That's not a problem but the point of the whole exercise! Peak shifting (better call it "balancing") is what leads to a more effective use of power plants and therefore to fewer necessary power plants. That means it showed success.
None of that would be a reason not to charge EVs between 12am and 7am and to get the better rate which it would deserve. This discussion is simply missing the key points.
Just a note that PG&E E6 TOU rates are partial peak 5 to 8 pm November through March. After 8 pm and weekends and holidays are off peak.
The chart applies to all of California - not sure how the demand varies by utility...EDIT: If the graph posted by drees (above) also applies to PG&E, then it would seem that 8pm is far too early for off-peak.
Unidirectional V2G doesn't have any discharging and thus does nothing to reduce cycle life. It allows EVs to be dispatched while charging around a given set point to perform frequency regulation, spinning reserves, non-spinning reserves, and peak shaving. Using proper control and revenue optimization can allow you to charge using real-time prices and actually be paid to charge. If you don't want control, the best sort pricing scheme is a double auction real time nodal price based on optimal power flow. The nodes in this case are determined by any distribution segment limited by congestion. But, it only works if enough appliances have a bid curve and your larger appliances like EVs are not price inelastic. If there are too many price inelastic customers and no control, you need to figure out what rate to charge people to pay for a bigger transformer. For Duke Energy's system, EVs can be charged the same rate as any residential customer as long as they charge at 6.6 kW or less.
Scott, definitely keep E-7. PG&E is proposing to change the E-9 tariff in a way that will significantly increase the cost for those who have solar to cover the usage.We're on the E7 plan, not the E9 plan. Which would be better? Not quite sure because it all depends on when you use the juice, but my bet is that E9 would be a bit more.
[snip]
So, I'd have to say, the relationship is somewhat adversarial - I don't trust them, they seem to do the minimum necessary to provide the service, often only when the PUC forces them to. Some honesty from them and some genuine moves to help customers and improve efficiency would go a long way. They are just not good corporate citizens.
