So was I. Was I not clear?I was comparing the whole house EV rate to the separate EV rate that requires an extra meter.
No, it's not. See my calcs. Here they are again:The payback is much longer than 5 years.
Adding EV usage onto my main meter will cost me about $0.30 / kWh to charge or at 3.5 mi / kWh about $0.086 / mi.
A separate EV meter will cost me about $0.14 / kWh to charge or at 3.5 mi / kWh about $0.04 / mi.
So I save $0.046 / mi with the EV meter. $2000 (cost of 2nd meter install) / $0.046 ~= 43,500 miles. Average person drives around 10,000 miles / year so you'll break even on your meter install around 4.35 years. I rounded up to be generous earlier when I said 5 years.
These rates are very typical for California. If you happen to live in PG&E country it could pay back much sooner - I understand their rates can be much higher. Not to mention that it will cost a lot less than $2000 to install a second meter at the same time your EVSE is installed in most cases - probably more like $1000 at the most and I'm still being generous. It took the guys who installed my 2nd meter an extra hour to install the socket for the extra meter while they were installing the EVSE. Inspector had to come out anyway to inspect the EVSE - so inspected the meter at the same time so no extra cost there. When he was done he called SDG&E who happily came out to insert the new meter at no cost to me. After all - that meter means another $2000 in revenue over 5 years which they would have likely not gotten if I couldn't charge on a separate meter at reduced rates.
Really the thing to do is to build it into the EVSE like the Blink - then you just have to get the utility to trust it - and use it.But that isn't the point, why not make a smart meter that can distinguish EVSE use from other electrical use. It avoids the permits, plan checks and the expense of installing a second meter. I see this as just one more obstacle to main stream adoption of EV's.
Right now it's pretty clear that they only trust your standard utility grade meter - probably because they are a known quantity that is robust and make it difficult to steal from the utility unless you're willing to deal with live utility wires.
