Thanks for the excellent responses. My concern stems from the fact that I have never seen a good model on Tesla's cost of goods. When I have tried to work it out, I get a very unsatisfying result. That is, I think the numbers show that a tesla model S (without a battery pack) costs way more than a BMW 7 series without a drivetrain. I think this is a reasonable assumption too for a few reasons that I should really write up fully...
So I concede the charge network advantage, and the perception advantage.... But, that doesn't help me as a stockholder if the BMW clone runs away with the market. Then Tesla is essentially just a poorly capitalized also-ran. I know I am skipping over the battery supply issue, and internal resistance (innovator's dilemma issues).
Tesla's advantages:
1) they have the right philosophy: design a BEV from the ground up
2) They have the right battery philosophy: standard format which gives economy of scale (panasonic supply) and build their own captive supply for growth in the GF.
3) The have good tech in the car. good, simple infotainment stack and excellent driver safety sensor suite.
4) direct sales model
How those can be neutralized by BMW:
1) They can design cars. They essentially did this with i3 and i8, they just chickend out and used a poor design and rex. They may not mess up forever.
2) They may punt and buy industry standard cells. Tesla is not buying the global supply, and they never got traction with non-panasonic suppliers. It would not be that hard to get enough cells to start, just as TM did. Then with BWM's weight added to Tesla's, the industry could spawn it's own GF's of new capacity.
3) TM isn't protecting it's patents... BMW could literally just reverse engineer everything and write their own SW. Not impossible.
4) screwed here in the US, but I think they sell direct everywhere else in the world.
I mean nothing is really too hard. I have not squawked too much about the patent thing before, largely because I was content that automakers would keep failing for long enough to give TM a long runway. If there really is a major clone effort that bothers me. We talk all the time about how Model S is Battery SUPPLY CONSTRAINED. If BMW truly came out with a clone that god forbid used the same type of cells then TM and BMW would be dividing the same tiny market, not expanding it. If they are using pouches then they are not a clone and not a competitor.
- - - Updated - - -
I will get off my rear this weekend and publish my cost of goods calculations to get some crowdsourcing help. I think I can prove that TM has poor COGS. It never really mattered when they had runway and were selling high margin cars. But it starts to matter a lot if you consider a "clone" situation.
Tesla's advantages:
- - - Updated - - -
As Auzie says, if someone else can help break open the total addressable market that's to Tesla's benefit even if Tesla's market share suffers some. Better 20% of a 10X market than 80% of a 1X market.
I don't see much reason to believe that's true. Tesla achieves a lot of savings with its vertical integration, something other auto manufacturers do not have. Someone cloning the S and it's relatively low run rates isn't going to get huge gains in some bottom line simply due to size. It might even be worse because it's hard to get vertical integration if the company is currently configured around wide spread outsourcing and distributed integration.
