Agreed. Also rsi on the hourly < 20 which is usually good for a bounce. What's your thought from EW?
Good point about the RSI. Regarding Elliott Waves, much depends on today's earlier bottom holding.
A common Fibonacci retracement of 38.1966% from the June high back toward the November low would be at $307.24. Today's low so far is $309.61, which could be close enough to validate a significant bounce point.
EDIT: Meanwhile, there were a couple of gaps this week that may need to be filled. A gap occurs when a day's high is lower than the previous day's low. They are often filled before too long.
Curt -good summary - what's your actual EW count at this point?
A three gap down daily candlestick pattern is actually considered a reversal pattern - 'sanku' in Japanese - and indicates seller exhaustion. Something to consider if this transpires tomorrow morning and looking for a bottom prior to the bounce.
Thanks! Didn't quite match the criteria of a 'sanku' because it wasn't a gap down open. However, considering it dumped to below yesterdays close, shortly after this mornings open... I think that the general concept remains valid.Nice call!
Thanks for posting that! Got me thinking about looking at more than just the daily patterns. So I took the charts out to the weekly pattern.
Looks like TSLA is starting to form a Harami (+) pattern on the weekly charts (I think it's also known as the "inside day" pattern), with a "fat" inverted hammer. So out of curiosity I looked at what TSLA did with this pattern on the weekly charts. I found 9 instances where this two week pattern formed. 8 out of the 9 proved to be bullish reversal patterns. Three of the bullish pattern was only one to two weeks, the others were fairly long. The one that failed and was followed by bearish movements had an extremely long lower shadow, way below the previous week. Fascinating.
If interested, here are the dates:
Wins: 11/18 & 11/25/13; 4/14 & 4/21/14*; 5/5 & 5/12/14; 7/7 & 7/14/14; 10/13 & 10/20/14; 12/8 & 12/15/14*; 1/12 & 1/19/15*; 3/23 & 3/30/15.
Loss: 10/5 & 10/12/15.
*only short run ups in the price.
For the TA oriented, The Harami pattern requires that the following day/period is the opposite color and only the real body is entirely inside the long real body. IIRC "inside day" requires the entire trading pattern is inside the previous day/period.
Weekly volume was the highest it has been in years. Remarkable, if you consider the shortened trading week!I suspect that many patterns fail during an active bear raid. I have concluded this was an actual bear raid, with the normally-low-volume Monday being used to start the raid.
Thanks for the graph. It makes it very clear how the bear raid happened. (For posterity, I will note that the final four candles are Monday July 3, Wednesday July 5, Thursday July 6, and Friday July 7.)
I'm glad I'm not the only fool seeing a local bottom. I already have a position from Friday bought at 309, and if we see confirmation of a bounce on Monday plan to make a serious play here.
Edit:Er, shouldn't that be a green hammer?
I'm digging that upper BB range.View attachment 235054
Looks like a hammer today. I'm thinking we are continuing to form a bottom. Also, we are back within the Bollanger Band.
Fri and today's candles look like the shorts are making a huge effort to prevent a bounce, but are not quite successful.
Edit:
Good point... the chart was skewed because I had pre-market activity turned on! Chart above has been updated to correct that.
