If Model S doesn't support AC-3-phase with at least 32A - i will cancel my order.
Hopefully with the European launch coming 6 months behind the US there will be time to sort this?
The PEM sits next to the motor - does this house the charger? (given that it charges the battery via regen)
So my question is; would a new/different 3 phase charger be "simply" a matter of a PEM swap?
ETA: Are most of the necessary electronics already in place on the Roadster (see below)? I know Tesla don't have time to upgrade the Roadster but is 3-phase charging possible for model S?
http://www.teslamotors.com/roadster/technology/power-electronics-module
Under the PEM Cover
Inside the Power Electronics Module, there are three major systems – power stages, a controller, and a line filter. The most complex is the power stages, called Megapoles. The Megapoles are large semiconductor switch arrays that connect the charge port or motor to the battery depending on if the car is charging or driving.
Within the Megapoles, there are six different switches, grouped into three pairs known as half bridges. In drive mode, each bridge forms a phase. Each phase connects to a phase of the 3-phase AC induction motor. In charge mode, only two bridges are required, one for each wire in the AC line.
