if you look at the raw data for the drive you'll see the lovely 'unknown' status for the first 9 minutes of the drive. The data accuracy indicates that it has obtained a data point at least one time per minute. Since there was no indication the drive started from the API until 3:41PM it is calculating the accuracy and starting time from that point on. It's using the last good data point from hours earlier to determine the starting milage.I saw the note that today the API was down for almost two hours. However, I am confused on my first drive listed today. It says I started driving after the outage, I drove 24 miles in 9 minutes, and it has 100% Data Accuracy. Something cannot be right there, especially given that I actually made a stop along the way that is not reflected (though could have been in the outage window). Could you explain it a bit please @Jdeck ?
I made a drive from Madison, WI to Rockford, IL and had a estimated soc of 2% left upon arrival. I made it to the supercharger with 1%. Unfortunately the API was out for the entire drive so I have no record of it. :-(. I was looking forward to recording my 240 wh/mile as it was probably my lowest long distance highway speed drive to date.
