Electroman
Thank you for that detailed reply.Source: I’m a mechanical engineer and pilot and therefore have taken several fluid dynamics and aero classes, but do not claim to be an aero expert:
Sharp angles cause separation of the airflow at the angle, which indices turbulence and increases induced drag.
Stainless is less smooth than a painted surface, so there are some losses there due to body material choice.
The inability to do a lot of curvature on the body prevents you from following the airflow, which again induces separation at the surface, turbulence, and induced drag.
Cyber is longer, which increases Cd.
All the angular wheel arches, etc are less ideal than a gradually curved surface.
Cybertruck still has a vertical (but slightly curved) front fascia.
Wiper is not concealed out of the airflow. It’s probably better to have the wiper there than not, given the flat panels, to help guide airflow around the edge of the windshield, but not as good as a concealed wiper with more complex body panels that can guide airflow better.
Frontal area is NOT part of the Cd equation, but is a factor in total drag *force*.
The tonneau cover has to be a big contributor to the good numbers as it prevents air over the roof from backfilling into eddies in the low pressure truck bed area. But the tonneau cover is still ribbed, so will induce some turbulent airflow over it.
Frankly, it’s great that the CT’s drag coefficient is as close to the Rivian’s as it is.
Never imagined stainless steel to be less smooth. I always thought they are naturally smoother than most surfaces except maybe glass.
The fact that tonneau cover is critical to get that CD means, if you are hauling stuff with objects that are tall enough that you cannot close the cover, that will show up in the reduced range. And most folks that actually haul stuff for a living have very little reason to close it and open it everytime.
