The announcement is on the Tesla Website: Tesla Provides Customers with Upgraded Charging Software and Adapter | Press Releases | Tesla Motors
I imagine the same, but that's going to leave you stranded. I'm thinking, if I'm at an RV park charging and it's a bad outlet, the fuse blows before I have a significant charge and I can't reset, I can't move to another outlet and will be stranded.I imagine it would be non-resetable, but also think it's probably not going to blow until it gets extremely hot bordering on being unsafe.
Indeed, I'll probably just keep my "old"/current one as a backup.The protection does not hurt, and probably is a good idea just like a GFCI. If the thermal fuse really is non-resettable, then carrying the old 14-50 adapter, or a second new adapter, with you might not be a bad idea.
- - - Updated - - -
It seems to me as if there is a great deal of faulty wiring out there. My UMC and 14-50 adapter don't ever get beyond warm on my home plug. However, I've even had 110 outlets fail to charge when travelling. The charging of a car uses the maximum safe continuous load for the wiring, which has probably never been done on some outlets. Proper wire gauge and tight connections are extremely important to avoid heat issues. I don't think that it is fair to attempt to lay the blame on the adapter when the problem is very likely to be caused by the outlet.
I doubt that, most thermal fuses self reset when they cool. No reason to expect otherwise here.
Late is better than never. Much of the article is partly a snow job. It is a reactive response rather than a proactive response as they claim. It would have been proactive to have suitable hardware and protective software in the initial design.The announcement is on the Tesla Website: Tesla Provides Customers with Upgraded Charging Software and Adapter | Press Releases | Tesla Motors
I'm sure there is bad wiring out there, however most, if not all of the Tesla overheated wires, adapters and connectors that I have seen, Tesla hardware seems to be at fault.It seems to me as if there is a great deal of faulty wiring out there.... I don't think that it is fair to attempt to lay the blame on the adapter when the problem is very likely to be caused by the outlet.
Tesla also falsly indicated it got a 5.4 star safety rating in other press releases. Tesla & Elon Musk have creditability issues.If you read the press release I believe TM did a good job of indicating that it was a house wiring issue
That looks like it might have started to overheat and melt.That's what I'm hoping for... especially since I already swapped my damaged (overheated/melted) UMC & adapter for a new one a couple weeks ago. There is a related thread: http://www.teslamotorsclub.com/showthread.php/25444-Melted-Charging-Adapter-Cord
Here's a pic of the new 14-50 adapter, with the "green dot" referred to above:
Yep http://www.digikey.com/product-highlights/us/en/bourns-mfrm-resettable-fuses/3173I doubt that, most thermal fuses self reset when they cool. No reason to expect otherwise here.
