JRP3
Hyperactive Member
More locations and eventually higher power, 120KW.I want to know about the future advancements in Tesla's Supercharger technology!!!
Does anyone know where and when the next Supercharger station will come on line?
Any plans for Superchargers in Richmond VA or Norfolk VA? Would love to be able to go to the outer banks NC but it's about 270 miles... Without a SC it would unfortunately be an ICE trip...
How much time did you spend charging? How many miles did you add?They were all super fast, and the car was done charging about the time we were done shopping and/or eating.
You consider doing Harris Ranch to Barstow direct. On a recent trip (Harris-Tejon-Barstow) I ran into two different S's that had done it, but required careful hyper-mileing.Here is the data from the trip, starting with Gilory, to Las Vegas, using four superchargers. We spent between 45 and 60 minutes at each. I didn't do the math for how much charge we added at each stop, but the data is there to figure it out (other than for Gilroy; my recollection is that we arrived there with about 20 miles rated range remaining so would have added 177+).
Gilroy: Charged to 197 rated miles (range charge). Trip to Harris Ranch was 113.7 miles, arrived with 78 rated miles, used 37.4 kWh, avg. 329 Wh/mile. Generally went speed limit.
Harris Ranch: Charged to 188 rated miles, dropped to 184 overnight. Trip to Tejon Ranch was 117.3 miles, arrived with 38 rated miles, used 42.1 kWh, avg. 359 Wh/mile. Had cruise set to 70.
Tejon Ranch: Charged to 181 rated miles. Trip to Barstow was 142.9 miles (taking 99 to 223), arrived with 25 rated miles, used 44.4 kWh, avg. 310 Wh/mile. Generally went speed limit. Used climate control over Tehachapie Pass, as it was foggy. Rated and projected miles dropped well below miles remaining to Barstow while climbing toward the pass but gained all of that back.
Barstow: Charged to 197 rated miles (range charge), which took about an hour. Trip to Las Vegas was 160.7 miles, arrived with 25 rated miles, used 48.8 kWh, avg. 304 Wh/mile. Had cruise set to 70, with a decent tailwind. Making it was never in doubt given the rated and projected miles. Highest elevation is about 4,700 feet, but Barstow and LV are very similar elevation.
Kevin, the posts I have read about supercharger locations being at capacity are the ones along Highways 101 and 5 and seem to be filled up with new owners who have just taken delivery in Fremont and are on the way home to parts south. Certainly, that is the main North/South commute corridor and use of those stations will gradually increase over time, but I don't think this is an early warning flag regarding customer base and superstation availability.
Philip Macafee
Anyone know if there were any mentions of the supercharger network during the Q4 call?
If I remember correctly Elon mentioned Texas, Chicago and Seattle over the next couple of months.
