-The large low windshield will allow a deer or cow to breach the cab in a 70 mph collision
-No roll cage
-No fire suppression
-No anti-icing
-No 4-way seatbelt harness
-Center seating allows no way for a driver to climb out of the cab after a rollover
-The hinges on the suicide doors will jam shut in a forward motion side swipe.
-The windshield is not reachable from the drivers seat, leaving no way to wipe it with a rag when it fogs after the defroster fuse blows
-Who told Elon that traction control on the tractor will eliminate jackknifes?
-Drive wheel fairings look like they will get in the way when trying to chain-up in the middle of the night in the wind and sub-zero weather
-No "T" handle for the trailer brakes
-No headache rack
I'm all for saving the environment. But the trucking industry is in desperate need of a safety revolution first. Here're some ideas:
-a button I can push in bad weather that jerks one of the drive tires and reads out on a display how much traction I have available
-an audio announcement I can have in bad weather at night that tells me when I am about to cross a bridge so I can line-up and "float" across the ice
-a powered 5th-wheel with axle weight sensors so I can properly balance the trailer and load the drives without having to use a CAT scale
-I need a display showing air temperature, road temperature and dew point
-I need cruise control that can switch between maintaining a set speed or maintaining a set tension on the tires
-I need a mixer for the trailer brakes that I can set according to the load in the trailer
-I need voice controlled access to road conditions and cams
WYDOT Travel Information Service (Laramie)
-Is there any technology that could help detect black ice?
-I'd like an audible warning if the trailer loses tracking with the tractor
-I'd like automatic trailer ejection if the rig is blowing over in a wind gust
- "…powered 5th-wheel with axle weight sensors so I can properly balance the trailer and load the drives…" Moving it forward or back to shift weight?
jack
