nwdiver
Well.... I may have connected the GND and Neutral to get "3" wires. It may have definitely worked :wink:.14-50 needs 4 wires and 6-50 had 3 wires so out of luck on rewire
Please, buy a HPWC!I know the HPWC is an option but I do not need one, plus I would not be taking advantage of the high current charge. Seems like an unneeded expense. Does anyone have any other ideas?
With all the connectors and adapters in place I don't think the UMC is a safe option for every day use.widodh,
I would not be unplugging the UMC very much. I would think maybe 5 times a year. I get mixed comments reading the many threads on the UMC. Do you really think the UMC is that unsafe.
. The Nema sockets are simply not designed to be unplugged every day. Over time it will cause wear and tear on the connector which will increases resistance thus more heat builds up.
The HPWC is really the best and safest route.
On the NEMA side it doesn't lock into the socket, so it could be unplugged while 40A is flowing over the contacts. The HPWC is a fix installation which locks into the car and cannot be unplugged while current is flowing.
A NEMA socket can be halfway inserted causing less surface to make contact which again leads to more heat.
In the UK Tesla isn't even supplying the UMC anymore, they recommend getting a fixed EVSE at home. You have to buy the UMC separately if you want want.
If you are spending >$80k on a car, please, don't try to save money on charging infrastructure.
You have to think about "the mass" buying a EV.Strong statements to throw around (that it's not safe). If I only unplug my UMC twice a year, there's no additional wear. Are you an electrician? Does the construction violate any standards?
Exactly. Anything else is FUD. I use only the UMC for charging, and plug/unplug it at least once a day. After 14 months, there are absolutely no problems, and no additional heat. Apart from the early UMC failures where they just stopped working, I have had no problems.RV parks use NEMA 14-50s. They are certainly plugged and unplugged several times a month. Maybe several times a week. It is an outlet. It is designed to be used as an outlet. People have been using them for years..
It may work but it is DEFINITELY a violation of code, not safe and can cause all sorts of problems. You should not do that.
(There is a reason they keep ground and neutral separate, or we simply wouldn't have separate conductors.)
Have you ever seen how most people use extension cords? They don't think about it, they simply plug it in and think it's OK. We are talking about 40A continues load for hours at a time. That can potentially cause issues.
The HPWC has been designed to take the "idiot" out of the equation. With the UMC you can still halfway plug in the NEMA connector which is dangerous.:smile:
So my statement about the UMC not being safe for every day use still stands. Potentially users can use it improperly and cause a dangerous situation. With the HPWC that's a lot harder to do.
... as some of you know, ground and neutral are combined in the circuit breaker box anyway. What's the problem with combining it 20 feet further down the wire? I build my own, it works beautifully, and I trust it.
I follow up any electrician and inspect the work on my home, and I know I often do a better job myself.
Or hire an electrician, some of whom have been known to do sloppy dangerous work because they are in a hurry, or new, or sick, or....
Cant you just change out your 6-50 wall receptacle to a 14-50? Already on a 50 amp breaker, should be an easy fix.
If you don't have the UMC with you you can use any of the 1000's or J1772 charging stations or superchargers out there.There are also a few reports out there of folks who unexpectedly found themselves stranded for a charge w/o their UMC b/c of the habit of leaving their UMC plugged in at home.
So, either purchasing a second UMC to always leave in the car and to act as a backup in case of failure of the daily use one, or, as suggested, buying the more durable, nicer looking, longer corded HPWC...that's the option I like as well.
I would just put a 14-50 plug in using the same wiring but just not wire the neutral. This is TOTALLY safe if you just use the UMC in it. Label it and just be sure to change it back to the 6-50 if you ever move. If you can run a neutral you can wire the 14-50 by code but this will not make using the UMC any safer.
