In the UK backup generators are allowed with some very careful caveats. For a typical house backup generator (which basically hardly exists as an animal in the UK, or EU for that matter) there needs to be a manual grid disconnect switch, and only after that should the backup generator be able to operate, i.e. the backup generator should be interlocked with the disconnect switch. Needless to say most of these things that I have seen over the years in 'domestic' settings are not done per the book, but that is how it should be. For obvious reasons. And - rather obviously - that is not a UPS. The sequence is : 1) grid lights will go out and stay out, then if you are at home 2) get up off couch, find battery light, manually disconnect grid incomer, then 3) go and start generator, then 4) connect generator to house switcboard. (prob 5) generator stalls and quits, curse, dump some loads off the switcboard 6) restart generator, then reboot all the crashed computers etc. Then some time later notice neighbours have lights on, 7) reverse sequence very carefully. In commercial/industrial UK locations only kosher engineered backups are conceivable. If not at home and lights stay out, tough, as no-one else in the house will safely be able to operate your home-brew lash-up.
The type of Powerwall sold in the UK is (I am fairly sure - and I have checked carefully in the past) not able to operate in a loss-of-grid situation. (I think) that functionality has been specifically disabled in order to obtain the most straightforward (and cheaper) grid certification. I think that same situation exists across the whole of the EU. Most grid-tie inverters available in UK/EU have similar limitations in this respect. (There used to be one that was available for a period - I am fairly sure SouthWestWindPower (SWWP, remember them .....) paid for the design/certification of that and its availability was er "strictly controlled", and if my memory serves me well it was made by PowerOne, was't it the MHI version or something, not the Aurora.)
My humble opinion is that what a lot of you are asking for as a "want" could usefully do with being very carefully described and limited to what is technically possible, commercially viable, and regulatorily permissible. If you write your "wants" out carefully in that way you'll soon realise this is not a thing that is hugely attractive for Tesla to spend a great deal of effort on. One day when Powerwall design evolution stabilises it will be worth them getting the EU certification done for blackout usage (and either the UK can then accept the EU certification, or stuff the UK they can do without). And only after that Powerwall design stability do I expect to see serious 'true' automatic V2G from Tesla using the Powerwall functionality as the certification 'hub' for the various regulatory zones .... including USA.
(one of the lead people in Tesla on this is UK-origin and knows the UK/EU scene well, this topic area is also very relevant to Megapacks and the other storage products)
Just my 2eu/c.
