It is also worth noting that while the battery temperature is indeed controlled and cooled/heated as necessary - if you are concerned about decreasing range over the years, supercharging every day is likely to accelerate that effect. Slower, overnight charging is better for the battery, and - as far as I know - keeping the charge between 20 and 80 % when possible.
I wonder what would happen to the battery of a Model S if you exclusively charged it with superchargers. How would the range of that car be after 8 years, compared to a car which was mainly charged overnight at home or work? If Tesla Motors are sufficiently smart, they will be logging which car charges when (in superchargers), to gather more knowledge on this over the years. If warranty issues start coming in over the years, before the 8 years are up, they could look back at the cars charging data and see if extensive supercharging was the cause. Superchargers were never intended as a daily charging solution - I wonder if there is any small print somewhere about this, to void the warranty or at least use it when people complain after 7 years and 11 months that they no longer get the range they paid for initially. I could imagine Tesla Motors using individual supercharging usage historical data in certain cases to explain a car owner why he only has - say - 80% range after 8 years and 200K miles.
As I have stated I am not in favor of charging daily at a Supercharger, but this has more to do with personal convenience and charging etiquette rather than battery degradation. In my conversations with Tesla on this subject they point out that the Superchargers are designed to taper off the charging current as the battery reaches a full charge. It is not Supercharging that leads to battery degradation, but rather doing maximum range charges regardless of whether it is at home or via a Supercharger. I haven't studied this recently, but early on the charging taper for Superchargers decreased the charge rate down to the rate of an HPWC when at high states of charge. I suspect that hasn't changed much if at all as the new Superchargers have been rolled out. Therefore, I believe charging daily with a Supercharger, especially at low states of charge, have no more effect on battery degradation than charging with an HPWC.
Having said that I still think it is still poor charging etiquette to charge daily at a Supercharger.
Larry
