Send them my way please, I'd also love to get the date and time back on the driver's screen under the speedometer.Wonder what folks would pay - to flash back to the earluer version. There ARE people out there that have copies of old versions and the talent to implement it.
It seems as if only about 5 more vehicles have been added to the Google spreadsheet since I started following this issue. If it were as widespread as some imply I would expect significantly more entries.
My car is affected and not on the list. Tip of the iceberg when relying on TMC.It seems as if only about 5 more vehicles have been added to the Google spreadsheet since I started following this issue. If it were as widespread as some imply I would expect significantly more entries.
Who wants to put their car on a public list as having been crippled? I can tell you mine is not on that list. I"d like to be able to sell it one day.It seems as if only about 5 more vehicles have been added to the Google spreadsheet since I started following this issue. If it were as widespread as some imply I would expect significantly more entries.
The difference is generally believed to be regen. As a comparison, on mine the readings are:After looking at the TM-Spy summary screen, two observations and a dumb question:
1) The pack comes with its history attached
2) Replacement pack has about half the charging (38 kWh vs 62 kWh) and less DC charging (2 kWh vs 7 kWh)
3) Dumb question: on the TM-Spy summary screen, why does DC Chrg opt + AC Chrg tot not equal Charge tot? Is the difference regen? On my old pack, DC chrg tot was 5 kWh and AC chrg tot was 17 kWh, but Charge tot was 62 kWh -- that's a lot of regen!
Of course I realized only a certain percentage would bother to fill out the form but I thought all of those who expressed concern here would have done so. The more people reporting the more attention this will get. The last few on the list show 100% capacity loss so I assume they get their packs replaced.This sheet is in no way representative of how many car are affected. Come on, you know that. The vast majority of owners don't even notice. Even less are members here and even less add their car to the list. I never bothered to add mine, neither have many others here.
That’s wrong. The customers are not complaining about something that’s specifically excluded, by which you mean degradation. The customers are complaining about the capping of their capacity, as you well know.
Reaching into the property of owners and reducing range, power, charge rate and making several other downgrading modifications to hide a dangerous condition the battery has developed is not a warranty dispute. We have established 200 pages ago that this act is not degradation.
I did mention this a few months back...it is because they have at top buffer of 3 percent...AND I get half Regen when my Bolt is fullRandom piece of info I just learned. The 2020 Chevy Bolt charges to max 4.175 Volt. I know they use different chemistry so it's hard to compare, but in Tesla terms that would be aprox 10-13% less than to what Tesla is pushing its battery.
What Tesla offered, in black and white plain english was a "limited" warranty. And one of the limits was:
"Loss of Battery energy or power over time or due to or resulting from Battery usage is NOT covered under this Battery and Drive Unit Limited Warranty"
Which sentence in the warranty do you think makes it warrantable? This clear sentence below indicates that battery degradation caused by usage is specifically non-warrantable. You just simply can't ignore that language or pretend that it doesn't exist.
Instead it seems to me that when certain damage due to usage is identified (e.g., by measuring Condition Z to see if it reaches a trigger level) then the BMS takes action (like it does in response to many other triggers) and limits voltage.
What you have to do is find facts to support is that Condition Z reaching the trigger level is a warrantable manufacturing defect or a battery failure rather than simply battery wear from usage, such as lithium plating. I see no evidence supporting that --- yet but it is entirely possible so I do not foreclose that
1) was there a bad batch of batteries that had a defect that happened to be installed over a range of cars over a range of years (unlikely)
2) was there some use case (one time supercharging in the cold? leaving it sit at 95%+ SOC over night?, electron bad luck?), or even other random event that degraded the battery (likely lithium plating) that the BMS had to address (as it addresses lots of other battery conditions) by limiting voltage. -- much more likely
So far it all points towards wear from usage, probably lithium plating, since only relatively few batteries are affected, rather than lots of them. And the affected batteries do not seem to be from a particular batch of batteries (which would suggest a manufacturing defect) but rather are spread out with no pattern discerned pointing toward some use cause rather than manufacturing defect cause.
