Just picked up my MY RWD today. It has been already established that it does not have the LFP battery pack, but there was some speculation on whether it was a soft limited LR battery or a new smaller capacity NCA battery. From what I am seeing, I'm pretty sure that it is the Long Range battery software limited down to 260 rated miles.
At the supercharger at 99% charge it was still charging at a 35kW rate. As we know, a battery actually charged to 99% would be charging slowly, not anywhere near 35kW. Also, at 100% charge, there is no limited regen warning, indicating that the battery can absorb the full regen charge.
Charge rates that I managed to note: (battery was only preconditioned for about 10 minutes in 30F temps, so it can probably do better)
80% - 53kW
85% - 51kW
90% - 45kW
97% - 37kW
99% - 35kW
For MY RWD owners this is awesome news. When charged to a displayed 100%, the actual battery is around 80%. This means 100% of the range can be used without concern about battery degradation just like the LFP battery in the M3 RWD. And better than a LFP pack, you can charge quickly to 100% when Supercharging. Really, the RWD is almost as good as the LR in practical range since one will not often charge above 80% in the LR.
Some other data points:
80% - 53kW
85% - 51kW
90% - 45kW
97% - 37kW
99% - 35kW
- The MY RWD weighs 4,154lbs and the MY LR weighs 4,416lbs, a difference of 262lbs. The front motor unit alone weighs over 200lbs, so you would expect a greater weight difference if the physical battery was smaller.
- The Shanghai LFP MY RWD weighs 3,920lbs. With a similar battery capacity, you would expect the NCA MY RWD to weigh signicantly less than this, since LFP is less energy dense.
