For artsci, madartist, or anyone else who has one of the Sears inflators...
I bought one too. (See my posts upthread.)
The first one came some time ago, before I had my Model S, and when I tested it I found that while it worked well, the pressure readings it gave when just giving readings were about 1.2 to 1.3 PSI lower than the readings it would give when set to inflate to a set pressure. So, for example, if set to inflate to 45 PSI, it would slowly read up to 45 PSI, then shut off when it reached 45 PSI, and then immediately show 43.7 PSI or 43.8 PSI. I called sears to confirm that I wasn't doing anything wrong. They said I wasn't, and that I must have a defective product, and that I should send it back, and get another one. It has taken quite a while for Sears to get me a replacement, and I just tested the replacement a few minutes ago. It turns out the replacement behaves the exact same way!
So what I am wondering is how do yours behave?
In the original post, you stated, artsci, that you compared the inflated PSI to the reading you received with your FOBO, but you never said that you compared your inflated reading with a reading from the inflator itself. I'm wondering if I should try to get a third unit, or if they are all going to do the same thing. I can live with this if I know one of the two numbers is accurate. I just ordered another digital tire pressure gauge, in an attempt to be able to tell which, if either, number is accurate. I bought this: Amazon.com: TEKTON 5941 Digital Tire Gauge, 100 PSI: Home Improvement
If someone who has this Sears inflator could tell me if yours shuts off at a given pressure, and then immediately gives that same pressure as the reading, that would be very helpful to me. If several of you say yours work that way, I guess I'll be sending this one back too, in hopes of getting one that works properly, the way yours work.
Thanks!
Andyw2100,
My Sears Craftsman inflator works exactly the same way as your. Yes, it will cut off at the set psi, then immediately drift down about 1-1.5 psi. I don't think it's a manufacturing defect. I think the pressure simply registers higher while the pump is adding more air into the tire. Frankly, I usually use a separate tire gauge to check the tire pressure before and after inflation anyway. I know it's an extra step, but I feel better about its accuracy.
As I mentioned in an earlier post in this thread, their new 20V version pumps faster. Unfortunately, it only has an analog gauge. However, since I'm used to using a separate digital tire gauge anyway, the faster pumping speed and the increased battery capacity is a welcomed improvement.
