only if there is no excess load by the house (kettle, oven, dryer, etc). but then again, I feel that I better charge 90-80% of my target by grid, have some buffer for the evening/early morning use and top up remaining 10-20% of my target next day with solar.I think I’ve nailed my set up. Famous last words
Since swapping from OVO, Octopus IO has been charging my car perfectly so far using 26A selected in the car. Hitting the target every time. So this is working flawlessly; Some/ any of the excess solar battery energy stored at the end of the day (at 23:30 or later) is going into the car, down to a reserve percentage I set for the batteries on each GivEnergy inverter (10% right now) for each battery pair. Then when they hit that limit all the rest is coming from the grid at 7.5p (if needed - hasn’t been so far).
6kW is the max draw for the car whilst charging (at 26A) with about 2-500w background load and 1kW extra spare available for any spikes (whilst the car is actually charging) (otherwise it’s) up to the max of 7.4kW from the 2 battery inverters. The charging on IO seems to be biased towards the end of the 6hr period, so that’s preferable. I think.
Perfect way to automatically use up all the solar generated, have a buffer till sun-up and add any extra if necessary at cheap rate. And any high house demand (if any) over that is at cheap rate also.
I’ll up my reserve battery percentage in the app slowly each month as we get more towards winter, eventually to 100% as I’m fairly certain I won’t last the whole day on battery alone then.
You can get very granular with forecasts, automation, etc, to eke out the last penny and all credit for doing that but for me I haven’t got the time. I will charge slightly over what I might need for the day (as an insurance policy) and accept that very occasionally I may export a kW or two (or 10!) that cost me 7.5p for 4p and take the 3.5p loss on the rare occasion - it’s peanuts. Getting it wrong and buying kWs at 31p is not peanuts though. So I’ll err on the side of caution and not fret about any export.
I’ve got some loft insulation to implement and a few other changes (less electric underfloor Mat usage, somehow. Probably add a couple of rads to replace). Maybe ditch the gas?
Loving this IO tariff with my GivEnergy setup.
Spent £2 this month (July) on electricity. Plus the standing charge.
Going on the long journey from “I think I want Solar panels”, through the entire maze of requirements and options, installers, DNO, to fully operational, to being mesmerised watching the electrons flying around on the app has been a trip.
I’m just flabbergasted by the performance of the panels of today. I’m seeing full cloud cover, rain and 2kW plus being generated. They Start production at 1w 20mins before sun up, it’s just unbelievable how good they are these days. Obviously the no cloud, full sun day is better but Wow. Impressed. Never thought they’d work in those conditions at all. Thought they’d shut down completely.
All the looking at panel specs, fretting over minimum start-up voltages, clipping, orientation, G99 approval, was a non issue luckily.
This is all with the help of everyone on this forum. So thank you one and all for all your very helpful contributions. To help me through the maze.
So, to re-iterate the answer to the OP - YES Solar panels are definitely worth it in the UK.
(With the caveat of getting a proper, sufficiently suitable solar and battery system installed and and being on a decent tariff.)
Thanks again one and all and may the sun shine on your roof.
have in mind - I quite often return home with battery at 20-30% SOC and I see that this is not entirely efficient to unload that 10 kwh battery to the car.
