After 3+ years of normal operation my Powerwall 2's Firmware was updated in early May and since then my system started counting all exports as Home Usage. I called Powerwall support and the Level 1 resource explained the new Firmware versions will not allow for the CT configuration to be swapped in software and I must have the CT physically swapped. I called my Telsa approved Installer and they came out and swapped the CT and re-ran the wizard to configure the Powerwall's. Everything seemed to be working fine but it was cloudy day so no exports on that day.
On the following sunny day, the system behaved the same way, the app reported all of the exports as home usage. So I called support again and they escalated to Level2. After two weeks of not hearing anything back I called again, the L1 tech explained the system is behaving properly and they had closed the case. At this point I am frustrated but being an IT and Technology guy I asked a few questions. 1st, I asked how much usage the L1 tech could see for the current day, he indicated he showed my system had used approximately 10.5kWh (which sounds about right for a vacation home with no one there). When I informed him that the app showed 65kWh he said "There is nothing else I can do for you, the system is working properly". I politely asked how I can get help with a Tesla Powerwall and the Tesla App not showing the same data. He asked me to call my installer and have them troubleshoot this. My installer is beyond frustrated, they asked them to travel out to the site again and use a meter to check on the flows etc.
Has anyone else experienced anything similar?
I realize that CT's misplacement is common in new installations, but this is not the case here. I've attached a couple of pics from the app where you can see the exports in Grey and then on the same day very low usage in Blue with one spike where my hot tub cycled on.
So in summary, my system is working fine but my Home Usage numbers are all jacked up. At the end of the past 2 months my local Utility reports the exports properly but I dont have accurate data on the home usage in the Tesla App.
