Attaching a PDF version of @dl003's excellent post above for safekeeping and review for those that want.
Yes you always want to look at the latest readings to decide what to do next, which is why I entered hedges at 194. However, the extent of the damage was well contained as not enough time has passed for the hourly divergence to escape from the influence of the daily bullish divergence.Fabulous write up and lots of good insight, I'm printing and saving this!
A couple of questions so I can understand better, as you said you invite discourse on your posts:
1) "Bullish divergence on the daily, which should trump bearish divergence on the hourly." Don't changes on the daily stem from the hourly, so a bearish divergence on the hourly is the most recent fact and it'll take some time to reflect on the daily and may be too late by then to take action?
2) Does $209.03 resistance replace the $206.86 strong resistance mentioned earlier on Friday?
Thank you.
For the stock to get out of and reverse from the steep sell off, one of 3 things must have happened: the big sellers found 175 to be too low to continue selling, big buyers found 175 too low to not buy, or both. These forces wont easily reverse just after a $20 bounce. Not only will they find $195 too low to stage another sell off, but they will also punish all the retail shorts that are trapped in this zone, and finally they wont stop until they have sucked in enough new bulls to make the next sell off worth their effort. So the key is to figure out what kind of buying/selling power is involved at every pivot and anticipate their goal.
206.86 is more definitive as it requires not only a break, but a daily close. 206.86 will act as both a resistance and an (at least) one-time-use magnet once broken. I dont see why you cant keep both on the radar.Thanks. I guess in sum we are in the wait-and-see zone. We are also apparently entering the historically worst two weeks for the markets which are the last 2 weeks of February (I don’t know if this is true). TSLA might have chosen the wrong time to break out OR money may rotate from other profits into TSLA.
What about question two:
Very nice!Attaching a PDF version of @dl003's excellent post above for safekeeping and review for those that want.
Going time to buy some cheap +185p/-180p 2 weeks exp and sell some -220c for fridayOne viewpoint: Tap $206 and fall with the market correction over the next two weeks.
If so, at least we fall from a high of $206 to $170 instead of $170 to $140
For those stressing about extrinsic value, of course it's a pure function of IV, so you need to watch it daily if you think it's getting tight
Just use Options Profit Calculator with Optimizer and Flow | OptionStrat or Options profit calculator to look at the projected value of the option over time and you'll see quite clearly at which SP you'll need to consider taking action
I will do the same except for the -180p. As the hypothesis is SP will reverse to around that area (slightly lower) with enough conviction to act upon with +185p and -220c, can you help me to understand the dilutive component of -180p of your plan? If the prediction turns out to be right, wouldn’t the -180p sold at that time amount to higher premium?Going time to buy some cheap +185p/-180p 2 weeks exp and sell some -220c for friday
Bail if we hit 215 got it
Thanks dl003 and Jim for the educational discussion
With loves,
The Dog
Perhaps the combination of +185p & -180p is a type of option play and it is that combination play that you referred to as “cheap”.I will do the same except for the -180p. As the hypothesis is SP will reverse to around that area (slightly lower) with enough conviction to act upon with +185p and -220c, can you help me to understand the dilutive component of -180p of your plan? If the prediction turns out to be right, wouldn’t the -180p sold at that time amount to higher premium?
Please keep in mind I’m new to this type of play; I believe it is me that’s missing something.
This question or chat is more about making use of these calculators to estimate option value. Assume closing the position, say ATM, it's 52k. That releases 168k of cash (CSP) , leaves 115K cash. Projecting out to the same expiry, deploying 102k and selling at about SP = 176, is $15.5k credit. Look right to you? Although it's about 15% return on the cash, is there a better use of the 102k? Buying shares at SP = 176 and assuming that SP can get to 225 by Jan 25, that's about 28k... and the opportunity to write 5 calls a week agains the additional shares (which I didn't calculate or set a fair expectation of what is reasonably safe) ... but also has no guarantee.Thanks. Is this about right how to do that. Shows danger zone around $166-$167 @ IV 46.3:
actually no. no bail if 215 gets hit. if 215 gets hit and the stock can keep and hold a 70 rsi on the 4h to 1 candle close, stay in. Price is not the only dimension.Going time to buy some cheap +185p/-180p 2 weeks exp and sell some -220c for friday
With loves,
The Dog
Thanks dl003. As always we stand by to listen in when thing change.actually no. no bail if 215 gets hit. if 215 gets hit and the stock can keep and hold a 70 rsi on the 4h to 1 candle close, stay in. Price is not the only dimension.
Although Im acknowledging the bounce can fizzle out soon and under what condition, my ultimate goal for this bounce, and maybe I shouldnt tell you this prematurely, is 235.
Considering the rapid market we are in, maybe me giving "if,then" 's too far into the future can do more harms than good.
Difference in cost mitigation but also cap earning max.True that the short put would be worth more sold at ground level ...
doggy is lowering cost of buying the long put
If $215 gets hit and the stock can keep and hold a 70 rsi on the 4h to 1 candle close, stay in. Price is not the only dimension.
Although I'm acknowledging the bounce can fizzle out soon and under what condition, my ultimate goal for this bounce, and maybe I shouldn't tell you this prematurely, is $235.
Considering the rapid market we are in, maybe me giving "if/then"'s too far into the future can do more harm than good.
