Doesn't seem to be any way to post comments. Doug?
I jumped the gun before Doug has all the kinks worked out. -twiddling thumbs-
My bad.
Good stuff. Perhaps you could have called Jack at the restaurant to save the charger for you? It would have been inconvenient to have to wait for the Leaf to depart so you could get your charge. Did the Comfort Inn reserve the charging spot for you? What if you got there late and another EV was charging overnight? What if your spot was ICEd?
I have a bit of charger-availability-anxiety.
So you did have to deal with some gas on your trip.To access that area, I had to go through the Taco Bell drive thru and wind around the back way
I wouldn't ask someone to save a charger for me -- first come, first serve. But I would ask another EV owner to let me charge IF they were only topping off. There were other 30amp chargers in the vicinity. Worst case, I would have gone and plugged in at 30 amp, gained some miles, & then switch over to the 70 amp when it became available.
Yep, agree. I was trying not to delve into the 'but that really means' part. Using something other than an HPC was 'worst case'. I haven't had to charge on anything but 70amp (this trip). And of course I'd plug into any outlet while waiting for the HPC --even if I only add two miles, that's two miles.
Ya, Ours is $4.22 for cheap gas at Costco today (down a little from a while ago)Compared to here, that $3.55/gal is looking pretty good actually.
