jimmyz80
I've been doing some bulb swapping on my roadster and figured I'd just add to this thread instead of creating a new one. So far I've had success with the following:
Dome Light
I used a WLED-WHP6 from SuperBrightLEDs.com.
194 LED Bulb - 6 SMD LED Wedge Base Tower | Wedge Bulbs | Specialty & Automotive | Universal LED Bulb Finder | Super Bright LEDs | Super Bright LEDs
It fits into the dome light perfectly, and is a LOT brighter and whiter than stock. Takes about 30 seconds to install from start to finish.
Front Parking Lights
I bought a pair of bulbs off of Amazon that appeared to be identical to what I used in my dome light, but a bit cheaper.
Amazon.com: JDM ASTAR Extremely Bright 5730 SMD 194 168 2825 W5W T10 LED Bulbs,Xenon White(Brightest T10 Bulb in the market): Automotive
As far as I can tell these are basically identical to the bulb mentioned above for my dome light, although the metal housing is visually a little bit different. Originally I had tried some "CANBUS compatible bulbs here since I thought the car monitored the current draw on these, but those bulbs would overheat and flicker within 30 seconds of installing them into the housing. These non-CANBUS bulbs I linked to above seem to be reliable, but I just installed them tonight and can't say yet whether the car will throw any errors at me once I start driving with them.
The best way I found to swap these is the following:
License Plate
Over on the Model S sections of the forum, I saw people talking about bulbs produced under the name Abstract Ocean. They are a perfect fit for the roadster as well, and seem to work well.
LED Licence Plate Bulb Kit - Abstract Ocean
Originally I had tried some bulbs given to me for free from DDM Tuning when I bought my HID kit from them. Those bulbs flickered and failed within 30 seconds. Definitely stick with the Abstract Ocean bulbs, since they are MUCH higher quality. Someone should talk AO into selling a 3-bulb kit instead of the 2-bulb Model S kit. The 3rd bulb would work great in the roadster trunk.
These take about 2-3 minutes to install.
I have some front turn signal bulbs on order that claim to be error free, so I'll update this thread once they arrive and I've tested them.
Dome Light
- Open the hood
- Remove the black plastic cover that runs the width of the car in front of the cooling fans (it has the washer reservoir cap protruding through it). There are 8 plastic trim fasteners to remove with a phillips head screwdriver, and one 4mm hex/allen bolt to remove.
- Once the cover is off, you can remove the rubber cap from the side of each headlight housing.
- Twist the turn signal bulb and pop it out to give you access to the parking light bulb.
- Reach in and upward with two fingers and you'll feel the little "spear" that the parking bulb is mounted in. There are two clips you need to squeeze with your fingers and pull to remove it. Some wiggling is necessary, since it looks like this particular bulb was never meant to be removed easily.
- Swap the new LED bulb onto the "spear" and make sure it remains lit even if you wiggle it around a little bit. If it flickers, you might need to adjust the little contact wires on the bulb wedge to make sure they're contacting the contacts in the bulb holder "spear".
- Do your best to re-insert the bulb and "spear" back into the hole you removed them from. It's a bit tight with the bulbs I used, but some gentile wiggling helped it all slide into place. One of mine snapped with with a positive click, and the other side just seems to be held in by friction. I don't know if the clip are worn out on that side or what, but the bulb seems to stay put regardless.
- Reassemble the turn signal bulb, rubber cap, and plastic cover.
License Plate
