Todd Burch
14-Year Member
Because Saturn engineers are able to design a proper front hood, but not Tesla? Seems like an odd statement.
Refer to old Saturn commercials in which they take a bat to the panels to show the resiliency.
3/ No one has yet explained what the mechanism of damage causation is - could it simply be a matter of lubricating the latch mechanism so the hood shuts easier? Is it caused simply by dropping the hood from too high a point? If so, would simply a different spec'ed air stay prevent the hood from ever hitting the latch with enough speed to cause the crease?.
4/ A cure. As others have suggested, it occurs to me (tho I have no knowledge of the way the latching mechanism is designed) that the simplest solution for Tesla would be a 'drop in' replacement, self-closing latch system. I expect this is easier said than done, may be impossible and will certainly be relatively expensive. I am a bit puzzled, though, why the rear hatch gets a automated closing system (with the Tech Package) but the front doesn't *especially* given this issue of hood creasing.
With panel gaps you could drive a Tesla through.Oh, right, those plastic panels on the outside... I actually thought that was a great idea!
It appears to me that that are a few of important issues that keep getting lost as this thread expands:-
1/ The issue is a particularly daft design flaw and should be remedied by Tesla ASA-flippin'-P! I am sup prised the Tesla haters have not latched on to this issue yet.
2/ A remedy cannot simply be achieved by making the metal thicker or tougher as it is designed to protect pedestrians in a collision - this is (I suspect) set in stone.
5/ For those who do not need to use the frunk, is there a setting to disable access to it using the fob - thus preventing 'just anyone' opening it (and, therefore, potentially damaging it)?
Regards and season's greetings to one and all,
Martin Winlow.
Just took delivery of my P85D last night. I've driven a Porsche 911 for 8 years which only has a frunk. The frunk on the P85D is VERY difficult to close in comparison to the 911 -- I could feel the hood flexing as I was putting pressure on it, hands about 6 inches apart on either side of the "T". The amount of pressure required was nearly as much as "doing a push up on the hood".
A double latch or one with otherwise more distributed tension would seem to be a step in the right direction.
You brought back an old thread.
The older cars had the double-latch system and they had a lot of issues with the frunk crease. When I had my older car, I'm fairly certain I did nothing to cause the crease since I never used the frunk, but the service center claimed I closed my frunk improperly causing the crease. It would cost $600 to from an outside service to repair it and I chose not to do it because I wasn't sure if the problem would come back due to, what I consider, a flaw in the design of the frunk. Tesla did do some continuous improvements over time to try and address the problem with newer cars, but I don't know if they solved it.
Newer cars now have a single-latch system that's a bit easier to close than the older double-latch cars. I traded in my older car for a newer one and I don't yet have the frunk crease <knock on wood>. Only time will tell whether the frunk crease will appear.
