ThosEM
Space Weatherman
I like this idea.
And please note that the teams that did the LA to NYC rally for Tesla had Model S equipped to display battery percentage charge, rather than rated miles. This was visible in photos of their dash displays.
So I asked them how close to empty they went when skipping SCs in pursuit of the maximum charging rate, and they responded (in comments on the blog, I believe) that it was typical for them to roll into the SC at 3% charge remaining. Assuming a direct conversion, that would correspond to 265*0.03 or 8 rated miles. That's a pretty slim margin but it illustrates how far the real pros are willing to go. Of course, for them, a stop at a campground or a Nissan dealership would have been catastrophic in terms of the rally goals.
I wonder if the "reserve tank" was also shut off for them. It seems likely since they clearly had customized software not available to private Model S owners.
I just sent this to ownership@
Ownership team - if you would pass this feedback along to product/engineering I'd appreciate it.
Feature request
At some point, I think it may have been firmware 4.5, Tesla changed how rated range was calculated and displayed. Specifically, prior to this version the rated range displayed to the driver was the full capacity of the battery, minus a reserve that is not accessible to the driver to keep the battery from bricking. After this version, Tesla reserved additional capacity that is accessible to the driver but is not included in the rated range display. In other words, after this change it is possible to drive below 0 rated miles.
I understand the business reasons for this change. Tesla is trying to make EVs easy to use for the masses, and emulating the behavior of an ICE car that has some gas left after the fuel gauge starts flashing E likely meets customer expectations. Unfortunately, this has a negative affect in that the driver doesn't know how much energy or range they have left after hitting zero. As a driver, you're left making estimations. On the forums, some have even described performing linear regressions to estimate how much capacity is left after hitting 0. In an ideal world, drivers would pull over immediately after hitting zero. But that's not what they do. They push it, because there is this unknown "reserve" and without data, they decide to risk it.
I would like an option accessible via the configuration screen to toggle how the rated range is calculated. Option 1 is the default, and is the current behavior, with some amount of capacity in reserve. Option 2 displays the rated range with 100% of the capacity is that is available to the driver. If you hit zero, you're done, the car shuts down.
I think this would meet Tesla's goals of making EVs as easy to use as possible, while simultaneously giving drivers the option to understand the actual state of the battery.
Thanks for your time and consideration,
<name, VIN removed>
