I have a 2023 Model Y with 15k miles on it (10 months old). Last week when charging at a supercharger on a road trip I got a “Charging stopped“ message and could barely get home. I noticed that AC charging still worked so I was able to get into a service center in a few days. Even before my service appointment, Tesla sent me a repair quote with the following action:
I am still without a car and its really hard to get in touch with anyone (they don’t answer in-app messages and only answer the phone maybe once every 10 times i call, and never return phone messages). I’m not even sure if service is working on it over the weekend or not.
I am curious if the actions above (replacing the contactor and controller for high voltage DC fast charging) are major repairs which one would expect to take a significant amount of time (contrary to what the advisor originally told me), or if it’s a relatively simple procedure. For example do they need to remove the actual battery pack to do this work, or is the car designed in such a way that replacing contactors and controllers is relatively trivial (swapping out some circuit boards etc)?
Has anybody ever had this type of work done? If so, how long did it take for you? I’m also interested (mostly out of purely personal interest) what this type of job typically involves? I understand the procedure for most ICE engine repairs, but EVs are newer to me so just curious what is involved here.
I’m also curious what may have caused this (manufacturing defect?) and how likely the replacement part is to last as this could be a major source of maintenance cost if out of warranty. They say EVs require less maintenance cost than ICE engines, but that’s not the case if I need to replace these parts every 15k miles.
- Correction: Contactor - Fast Charge - HV Battery (Remove & Replace)
- Correction: Controller - High Voltage (Non-Structural Pack) (Remove & Replace) - Remove
and Replace
