I'm basing it on this definition as a direct quote from the paper (p4):
A vehicle that functions as a full-performance battery electric vehicle when energy is available from an onboard RESS and having an auxiliary energy supply that is only engaged when the RESS energy is not available.
As I said recently, after reading the paper again I think the "full-performance" part of that is just descriptive and not part of the normative definition.
Actually what you quoted makes it quite clear:
As a full-performance battery electric vehicle, the battery, motor, and power electronics must be sized for the full capability of the vehicle.
This makes it pretty clear my interpretation is correct. It's not comparing EV vs CS mode, it's saying that in EV mode you get the full capability (0-60/top speed) in reference to the car itself as a whole (all modes). If a car gets a slower 0-60/top speed in EV mode that means there is at least one part of those three components that's not sized for the "full capability". In the case of the ELR and Fisker, it's the battery (doesn't deliver enough power on its own to give the full performance without the ICE kicking in, exactly the
same reason why the Prius needs the ICE on for acceleration even though the motors can provide enough power).
So "It's not comparing EV vs CS mode" but actually it really is? That seems like an incoherent argument.
I'm not sure about the Fisker, but the ICE does not kick in on the ELR unless the battery is empty and the vehicle has already switched over to hybrid mode (same as Volt). What some people are complaining about is that the ELR goes 0-60 mph faster in hybrid mode than it does in EV mode. The Volt is about the same in both modes going 0-60 mph but diverges at 0-70 and from 45-65.
I showed a table of 0-100 mph performance values of the Volt in battery-only vs. hybrid mode taken from a MotorTrend article. That data demonstrated that the Volt is also faster in hybrid mode much like the ELR. Do you really think the GM engineers who wrote this paper (and were working on the Volt program) meant to define EREV in a way that excluded the Volt?
I don't see how your interpretation (that it's based on performance of other cars in its class), makes any sense in engineering, as whether a vehicle is "competitive" in its class is going to vary depend on which class you consider and how strict you are (for example the Energi gets 85mph top speed and 0-60 in 15 seconds in EV mode, so does it qualify as an EREV?).
Again, I don't think "full-performance" is really part of their normative definition of EREV any more than the battery packaging is.
For example, in the same paragraph you are quoting from they say:
The vehicle must also be architected to allow packaging of the large EREV battery which has a greater size due to the full EV requirement.
But earlier the say:
An EREV is typically also architected to accommodate packaging of these systems while retaining performance and utility.
I think the core normative definition is that a vehicle operating on an EREV strategy:
...does not need to start the engine for speed or power demands from the driver...
They were a little loose in what was normative and what was merely descriptive.
For what it's worth, I think most people would agree that the Volt is in the same competitive class as the LEAF and Prius. I could post a table from another MotorTrend article comparing performance between those 3 cars at speeds between 0-100 mph with the Volt in battery-only mode. In summary, all 3 were about the same from 0-40 mph and then the Volt performed better at the higher speeds.
By the way, why would it make "any sense in engineering" to artificially limit the performance of the hybrid mode in the Volt or ELR so that it performs no faster than the battery limitations of the EV mode? Why would anyone do that other than other than to satisfy irrational EV purity demands?
I've already said that I think the Ford Energi's optional "EV now" mode would quality as an EREV operating strategy if Ford made it the default when you start the car. They chose not to because they knew its performance was not fully competitive.
The key difference between ordinary PHEV and EREV is whether the engine will start up when the driver stomps the accelerator or drives up steep hills at full speed.
And on the subject of starting the ICE, the paper also says:
An EREV does not start the engine until all useable on-board electrical energy has been used.
The i3 REx doesn't allow the user to start the ICE until the battery is depleted. In the Volt, the user can start the ICE using mountain or hold mode. I'm pretty sure mountain/hold mode came after this paper. This is aside from maintenance needs (which you say may be necessary for all PHEVs).
I don't think they meant to preclude the driver from intentionally overriding the default strategy of the car. Why would they want to do that? They meant that the driver could not
inadvertantly start the engine by accidentally pushing the accelerator too hard.
In any case, the European version of the i3 with the range extender
does allow the driver to intentionally request the starting of the engine, according to usually reliable bloggers. The US version does not allow this, apparently in order to be in compliance with certain CARB regulations.
As for the point about series PHEV. That was how the Volt was advertised as a concept and up until 2010 (when it was revealed that it's a series-parallel) that's what most people referred to it as (and some still do today).
So?
You earlier said:
Originally GM's definition was much simpler: EREV = series PHEV, but they couldn't use that definition after they changed the Volt's design.
You still haven't offered any evidence in support of that claim.
As for those arguing that EREV is less confusing than PHEV, are you advocating we call all PHEVs, EREVs? Because so far, EREV is an additional term on top of PHEV, not really a replacement term.
Certainly not.
I'm arguing that GM's notion of EREV conveys a useful and important characteristic. It says that if you stomp on the accelerator or climb a steep road at the highest speed the car can go in its default operating mode that it will not start the engine unless the battery is "empty".
A non-EREV plugin hybrid would start the engine in those circumstances in order to supply additional power.
