Speed is one of the things that I've been recording. Most of the trips my wife is the driver, and she has been setting TACC, when available, to 68. When it has not been available she almost certainly never goes above 70, and is probably closer to 65 most of the time, when on the highway. And about half the typical trip is not highway, but 50 or 55 MPH max speed, so I assure you we are not anywhere close to 70 or 75 MPH there. We also don't use TACC when not on the highway, because of how inefficient it is.
The main trip--between home and work--is 52 miles and change, and the driving time in EV Trip Planner with a factor of 1, which is what we use most of the time (occasionally we use something slightly different, depending on what happened that trip) is exactly 60 minutes.
The last trip I recorded I was the driver, and I actually set the TACC to 65, to try to see if speed might have been playing a factor, as someone here had indicated that they thought torque sleep wasn't kicking in at all at 70 MPH, and I normally would have set TACC at 70. It made no difference.
So driving speed does not explain why we're not seeing torque sleep efficiencies.
Hey Andy,
It seems you are doing everything right so it comes down to whether:
- Torque sleep is just not working
- Torque sleep is working but other consumption factors are hiding or minimizing the benefit you see relative to your pre .139 numbers (and relative to EV trip planner)
Besides your own numbers and analysis, the numbers Tesla provided also indicate virtually no improvement so I understand your concern.
As there are so many variables involved it makes it hard to prove to Tesla (particularly if you're working through various "middlemen"). One thing I wondered was whether you had tried to duplicate Lolachampcar's description of when and how the car switches into torque sleep. Others's have described how the energy usage changes when the rear motor drops out. If you were to do a flat run, warm battery, range on, heat off (temporarily) and have your wife do the necessary steps while you are videoing the dash along with before and after consumption figures. My understanding is that the change in energy usage should be very noticeable and comparable to the behavior described by others on the forum. Obviously if it seems to be working from this point of view, you are still left with questions; however, if it doesn't behave as expected you have some more ammunition to push Tesla service.
