250 miles on a charge!!!
That new EPA figure for the P85D is just about what I predicted.
its heavier, faster and yet Tesla claimed it would somehow do better or equal mileage!
Hehehe, my wife is so tired of me talking about the car and checking websites constantly that I fear I have already ruined the car for her. But that's OK, she can drive the e-up instead:tongue:Thank you BASF - great review of your ride. All of these help us who are waiting. I think INSANE mode is the period of time between when you order a P85D and actually get it... I know my family thinks I'm INSANE for the amount of time I'm spending devouring everything P85D online I can get my hands on.
I stand corrected.The picture of 480kw on the speedo made my day this morning.
That claim was for the S85D, not the P85D.
not true - up until early this week they were claiming the same mileage rating as the P85 on the configuration portion of their web site ordering page. Now they have reduced it SIGNIFICANTLY (down to 242 with 21" wheels). What you originally ordered has been downgraded from a range perspective and they havent let anyone know on the order list - you get to find out only if you go and review the new spec published on the build section.
This is not true either. The basis for the range estimate has changed, that is all. If you drive the car at a constant 65mph on a dry 0% incline with no wind on a warm day, with no HVAC, then apply the original range. If you drive the car as per the EPA test, apply the EPA number.
Either way, your (real world) mileage will vary considerably.
I stand corrected.
It approaches 6C discharge rate.
This doesnt hold to logic.
If testing was constant across ALL cars then why only the change with the P85D? The fact remains that all things remaining the same, Tesla overstated the original range specs. There was little to no change with the other cars and their published specifications. Therefore, we can only conclude there is a special measurement for the P85D and its been singled out across the offering or they overstated.
Of course mileage will vary but they created the baseline so a consumer would understand what they were purchasing...and then they quietly made a change to that statement.
forgive my igrnoance, but what is C a measurement of? i have seen it here and MANY times over on diyelectriccarforums. i just dont know what dimension of electric cars it is displaying.
C- and E- rates – In describing batteries, discharge current is often expressed as a C-rate in order to normalize against battery capacity, which is often very different between batteries. A C-rate is a measure of the rate at which a battery is discharged relative to its maximum capacity. A 1C rate means that the discharge current will discharge the entire battery in 1 hour. For a battery with a capacity of 100 Amp-hrs, this equates to a discharge current of 100 Amps. A 5C rate for this battery would be 500 Amps, and a C/2 rate would be 50 Amps. Similarly, an E-rate describes the discharge power. A 1E rate is the discharge power to discharge the entire battery in 1 hour.
Telsa has posted a series of numbers for the various vehicles.
I suspect the first set of numbers (which didn't say how they were produced) were based on 55mph at constant speed. People were comparing these numbers to the EPA numbers and thinking that an S85D would get 30 miles over the S85. Then Tesla provided numbers at 65mph for all the vehicles which narrowed the S85D's range to just 10 miles more than an S85. Finally, they've provided EPA based numbers which sees the S85D equal to the S85 and the P85D losing ground. While this is confusing to the customer and could have been handled better. I do not believe they were overstating the range, I suspect the numbers they posted were all correct given the test conditions. There's a reason why the term "your mileage may vary" is in common usage. Because it really does vary under differing conditions.
Consider there are literally pages of questions in this thread about how they achieve it, and it turns out that they don't. It was likely being overstated in the first place because we know that the other cars have not changed their spec....I don't believe that the EPA centered out the P85D by itself yet the other cars remain the same. So all things being equal in the final analysis (regardless of it being 55, 65, or more real world), they made a mistake in their favor.
If it does then I suggest you talk to Tesla. I'm sure they can cancel your order (probably even giving you the deposit back) or converting your order into a different vehicle configuration that will have more range in the city.[/QUOTE
I understand that's an option thanks for pointing out the obvious - Tesla support and the sales process in general is quite exceptional...and I'm not hear to bash it, nor the car if that's what you are hearing in my posts.
Step away from your love of the car for just a moment and consider it from the 50,000 foot view. I didn't publish their numbers - they did. Thanks for the reference to the SAE report - I will take a look. That said, regardless of my driving habits, its a point of fact that the range was touted as one of the hallmarks of this engineering marvel - specifically it was noted to be on parity with the other MS offerings in terms of its range. And, I don't think I ever used the word "deceptive" (if I did that's me overstating) . I believe that I said 'overstated'. And, whether that was intentional or not, its still factually what happened. If you're good with their restatement of range that's great for you. For me, as I have previously stated, I think its at the very least a caution flag.
