I am swapping out the XT910 to XRT970 in preparation of 8/30 track day. The XT910 was used for five 15min sessions at Laguna Seca a few months ago, plus 1200 street/highway miles which does not contribute to much pad wear.
Measurement of XT910 rear pads. The new pad is 9.7~10mm.
After five x 15min sessions.
Right/inside(piston) 8.24/8.58 (leading/trailing) - Right/out - 8.59/8.16
Left/inside - 8.13/8.24 - Left/out - 8.3/8.00
Analysis of wear.
1. Laguna Seca is a counter-clockwise track; there are more left turns than right turns. From the extra wear of left rear, one can deduce the traction control is using the left rear brake to facilitate rotation of the car.
2. The rear pad has some unusual wear behavior due to the stagger pad alignment. As pointed out in previous posts, the rear inside and outside pads are not alignmented. The trailing 7/8 of the pad is lined up with the inside pad, while the leading edge is ahead of the inside pad. This causes the trailing edge of the outside pad to wear more than the leading edge. The inside pad wears as expected, with more wear on the leading edge.
3. To even out the pad wear, I would rotate the entire set of the pads from one side to the other side of the car. When doing so, the inside pad remains inside, but the leading edge will flip. With a typical caliper, rotating inside with the outside of the same caliper would do the trick. Anyhow, learning something new about the P3 every time I work on it.
Previously taken photo of the staggered pad arrangement.
@destructure00 had pointed out a c-clamp might be necessary to get the hydraulic piston to retract enough for new pads or rotor install. I use a hack to this done. Angle the pad into a wedge position to create a larger opening that is big enough to go over the edge of the rotor. Once position the pad/caliper on the edge of the rotor, a couple of firm push of the caliper toward the center of the rotor/axle will push back the piston and get the caliper on the rotor in one motion. A couple of millimeters might be the limit of this hack. If the piston needs to be retracted more than that a c-clamp or piston press would be more appropriate, please use your best judgment.
A minor upgrade, see if you can spot it in this photo.
A proper M6-1.0 x 16mm flat head countersunk screw to replace the stock hex bolt.
