Model 3P 2019:
I was able to retract the rear driver-side caliper piston and install new pads; but I cannot do the same on the passenger side (I'm confused and tired after trying for two hours).
My procedure for both was:
-Remove caliper from bracket
-Set the towing service mode
-Unplug the electronic brake wiring just in case
-Remove pads
-Open the brake fluid cap
-Twist clockwise the piston with an adjustable tool that has two pins (I hate it because it's so adjustable it always comes off)
(do this for a while)
-Provisionally place the new pads to see if there's clearance vs. the rotor
This worked fine on the rear driver-side. But repeating the same on the passenger side I eventually start hearing that I'm turning some of the assembly inside (sounds like the motor/some gears). Even after a lot of fiddling I haven't increased the clearance, the old pads just barely fit on the rotor. I even put things back with the old pads, went out of the service mode, and re-did the sequence.
Only other note is that I have the MPP rear big-brake kit which needs more gap between the pads since the rotor is thicker. But then again I was able to do it on one side!
Any suggestions are welcome. Do I need to do the 9V battery trick to retract the electronic parking brake further?
I can always put back the old pad on the difficult side until I figure it out.
-Remove pads
