I've always wanted some sort of enclosure for the umc so i can securely bolt it to the wall to avoid theft, since I park in a carport. Anyone seen that sort of thing? Otherwise I will continue to plug/unplug it every day.
The issue I've always had with letting the UMC "Body" dangle has been more with the stress it puts on the interface between UMC cable-plug and the adapter that fits in to it. That interface has had issues in the past (hence the adapter replacement program), and the pins in there are only barely adequate for the current[1].
Leaving that weight unsupported increases the likelihood of stress on that interface and some unwelcome play developing there. It's one of the reasons I carry a couple of velcro straps and a small bungie in my UMC case.. I've used them to support the UMC a couple of times on trips. Not to mention they serve double-duty in allowing for a tidy UMC cable when you coil it up.
[1] In my opinion, and that if a number of other folks here...o
I would think that shouldn't be a problem. The adapter clicks into place with a mechanical "switch", and the only way to remove the adapter is by pressing the button to release it. As long as the outlet is installed such that the plug's stress relief angles straight down, all mechanical stress will be on that switch. So I don't anticipate any stress going through to conductors and connectors.
Just a thought, but I'd recommend a different approach there, having the cord draped across the stairwell like that seems to be asking for trouble.
Was looking through Tesla Gear, and even though this is listed as "replacement wall connector cable organizer for HPWC", it works just fine as organizer for the UMC.
The link says it can be shipped to customers with a North American address. Canada is still in North America, isn't it? :wink:I wonder why this is only available in the U.S . Can't see any reason why it couldn't be available in Canada.
Oh well..I'll continue to use my spare garden hose holder until I can buy it.
Just a thought, but I'd recommend a different approach there, having the cord draped across the stairwell like that seems to be asking for trouble. I'd probably have it run under a cover of some form to a hanger on the side of the stairs closer to the car... (actually I've posted elsewhere what I would do, but not everyone agrees, I'd have the wire go up to the ceiling, and dangle right beside the charge port on the car so that you never need to touch the coil, just open charge door and plug in, when you leave just unplug and let dangle...)
I thinking having no rail on the stairs is more dangerous. At least if you trip on the cable, you're already at the bottom of the stairs.
