AlanSubie4Life
Efficiency Obsessed Member
Original capacity for that vehicle is 52.5kWh to show 240 miles. If you have less than that, you will not show 240. Most (but not all) vehicles started with at least that. And usable initially is 95.5% of this, 50.1kWh. So each of the 240 displayed rated miles has an energy content of 50.1kWh/240rmi, or 209Wh/mi.James@Tessie, given that the "Usable Capacity" on the health page includes the buffer, should we be using the nominal original capacity in order to get an accurate before and after capacity comparison? For example, for my 2019 Model 3 SR+, Tessie recommends 51.6 kWh for the original capacity:
...but I believe that would be the "original usable capacity" and does not include the buffer. So should I bump that to the original nominal capacity to include the buffer to match the current capacity which also includes the buffer? If so, does anyone know what the original nominal capacity of my model would be?
The buffer is always (for Model 3/Y) 4.5% of the nominal full pack. 95.5% of NFP is the usable quantity.
This is all extremely well documented here with rock-solid evidence base. Just search for 52.5kWh and look for screen captures and pictures of the range. Or 209Wh/rmi or 209Wh/mi.
Charging constant is 219Wh/rmi.
As you can see, it is straightforward to determine your current usable and full pack capacity with this info.
Note for the 2020 it went to 250rmi with no relevant change to the pack or vehicle. That was a software update which also applied to your car to improve efficiency, but did not change your constant (since that is not changed from the EPA value - which was better in 2020 than 2019 (2018 actually I think) because of these several updates). 210Wh/rmi or 200Wh/drmi.
