Thank you for contacting Tesla Motors. We appreciate your feedback and the request for the NEMA TT-30 adapter. We have had several requests for this adapter and the charging team has been informed. We are optimistic that the TT-30 will be considered for addition to our adapter lineup in the future.
Regards,
Hugh
Ive gotten 6mph from a 120v 20 amp outlet (16amp charge rate). Without the voltage drop on the line, I might have gotten 7 or 8. Using a TT-30, heavier gauge wiring, should not have the voltage drop. Still, it will beat a 15 amp 120v.And in real life nobody's ever got close to 8mph from 120 (it's much less efficient). My guess is that you'd get more like 4-5 miles per hour of charging.
It might be the case that the 20Amp limit on the charger at 120 volts is an actual hardware limit, not just a software thing. Meaning it needs the full phase to pull 40amps (it splits the 240 volt full phase into two 120 volt split phase 20amp circuits). Just a guess. Although if the car were equipped with dual chargers, then maybe more than 20amps is possible.
I very much doubt the 20a 120v limit is in hardware. I suspect software and an over zealous programmer.
Btw, why the renewed interest in charging from a TT-30? They aren't that useful...
Does that site have two TT-30s? I ask because I built myself a TT-30 combiner to get 240v from them...
I agree! I am pretty sure that Tesla could come out with a software update that would support a TT-30 adapter to charge at 24 Amps.
Has anyone looked at the PWM signaling coming out of the UMC during 120V charging? This could be firmware in the UMC that notices the 120V and limits the PWM to the car to 20A, but I doubt that. If the limit is in the UMC, and update would be more difficult.
Stick with the Campco parts, I tried the Conntek TT-30 plug and one leg started to melt slightly.
