Most likely they know the temp. All pressure sensors I worked with have temperature sensor built in for temperature compensation of pressure measurementWould it require rocket science for the TPMS to take the ambient temperature into account? Wait, even if it would...
I only got it the morning after we had windchill in the negative teens...I never have a problem with Regen. I can feel when it's limited and I adjust accordingly. No biggie and I hope they never change. Putting Regen on brake is bad.
I've never seen the snowflake. It hasn't been above 20F in Chicago for 2 weeks. Mostly single digits or negative. What gives?
I suspect so... I've been temporarily displaced from mine...Wind chills last week were -30F at night but I keep my car garaged. Maybe that's all it takes too avoid it.
Garage helps a ton, we’ve been in the single digits here, but my garage is typically around 45 or 50 inside according to the car.
Took my car out for a short drive in low-single-digit temperatures yesterday, parked for lunch, then drove home. For the duration of the entire trip I had zero regen (despite having warmed the car up before leaving). So, question for all of you single-pedal drivers out there: what do you do under these condition (or, for that matter, when you've just put on a trip charge and have no regen due to that)? Do you ever find yourself taking your foot off the accelerator and wondering why you're hurtling toward the car in front of you? A driving mode that relies on an unreliable deceleration mechanism seems rather dangerous. Wouldn't it be safer to put the regen on the brake pedal and have everyone consistently use traditional two-pedal technique?
Specifically it being (only) on the "accelerator" pedal, and not just regen in general?I would hate to see regen move to the brake pedal. It’s one of the things I love most about the car.
Yes, one pedal to rule them all.Specifically it being (only) on the "accelerator" pedal, and not just regen in general?
I would estimate that of all of the times I've gotten a low pressure warning in cold weather fewer than 10% of the time was adding air the right answer. The other 90+% of the time simply waiting was the right answer. So, for me, at least, your approximation is wrong 90+% of the time. And I have never intentionally removed air from my tires. Ever.They need more air molecules in winter and less in summer. So you need to add/ remove air as the seasons change.
