Hi,
So i am the owner of an 2013 ms p85, wich from when i purchased it july last year has been an emotional rollercoaster.
In my short ownership the car received following repairs:
- doorhandles (all) to gen 3
- changed driverside window regulator
- changed DU to and "new" refurbished
- changed all of the suspension arms and links in the front
Due to an accident where my car was hit from the rear left side, all suspension parts on left front and back were changed out.
- the 12v battery was changed
- the speedometre screen was changed
So to the problem:
The last 2 weeks the car has been throwing error codes my way, where in the start it was every second day and now its daily.
And it starts with what i perceive sitting in the car as an small power surge/jolt followed by one or more error codes.
ESP/Stability control goes, Regen goes , sometimes antispinn, the power steering (sometimes reduced, sometimes gone).
I had one day where it just was hammering error codes (the audio chiming alarm was non-stop).
All the above is fixed when i power off the car.
How long the fix lasts is very variable, sometimes it comes back in 5-20 minutes, sometimes the next day.
I hoped long and well that perhaps the source of this could be the famous earth studs located under the frunk.
So, today i checked those, and the one on the drivers side (red ring) has been replaced and someone had put a new bolt in a new hole on the frame. Did not touch this as it looked good.
Passenger side (green ring) was the original stud, wich i took of the bolt and the ground wires, sanded all down, cleaned and remounted it.
Due to the sanding i did around the stud and on the grounding connectors i am well and sure about this side.
So - i was out this afternoon with the car and after driving 20 minutes the same error came back, this time i felt a jolt in the drive, like the car got pushed/accelerated before it stopped.
Oh, and i have had Tesla remote diagnose it, and they have asked me come to the nearest shop for an " low voltage circuit integrity check " , only problem is that the only available time is 3 weeks from now.
I have googled alot, searched this forum, but i cant quite find someone who has the same issues and error codes -->
ESP_w003_tcDisabledByFault
ESP_w002_espFaultLamp
EPAS_d076_KFC_DAS_TIMO
EPAS_d011_KFC_COMP_L2
EPAS_d010_KFC_COMP_L1
I have attached photos of the error codes:
So to the problem:
