It is not the cost and it is not the size of radiators - it is the air/radiation cooling of the motor rotor.I'm sure it would be no biggie for Tesla's engineers to design a more powerful cooling system. They probably don't do it on Model S for cost considerations (and maybe also cosmetic design considerations - it has rather small radiators).
Permanent magnet motors achieve the highest power-to-weight ratio of any motor type. Most PM motors are water-cooled. In such motors, coolant fluid circulates through a jacket around the stator. Such motors deliver good short-term performance but their rotors tend to overheat during continuously demanding conditions such as race-track use. Besides of the inconvenience of a time-limited performance, such motors are in danger of demagnetization which can permanently damage the motor. Rimac motors are rotor and stator cooled with low viscosity oil which is pumped by an integrated pump. The integrated heat-exchanger transfers heat to the external water/glycol circuit which is circulating through the vehicle and radiators (the oil stays always inside the motor and does not circulate through the vehicle). This unique design is the guarantee for flawless performance even during very demanding race-conditions.
Garage 1 at Sonoma has a NEMA 6-50 but that is the only publicly accessible (and you typically have to pay to rent a garage for the day) high voltage outlet I know of. All the Laguna Seca garages have 6-30's, and Thunderhill has a bunch of 14-50's. I have been scouring track facilities when I'm there in preparation for an electric motorcycle in a year or so.Great stuff, Doug_G! Love the profiles idea!
One of my ICE-loving, "you-greens-are-idiots" friends has been challenging me to race against his Corvette at the Infineon Raceway in Sonoma. I'll keep the race to one lap Or, take him to the neighboring drag strip instead. There are unfortunately no charging stations there, I believe.
Maybe I missed this, what was the temperature outside during your run?
It is not the cost and it is not the size of radiators - it is the air/radiation cooling of the motor rotor....
Oil-cooled rotor also has higher friction (i.e. losses) than air-cooled one. Such track-ready Model S would have significantly lower range even at everyday usage. IMHO it is not worth it to Tesla to spent RD on such motor at least not for the time being.
Model S has a liquid cooled motor and inverter.
So I take it you monitored your projected range and it never fell below 30 miles or so? At 1200Wh/mi, you only have 71 miles of projected range with a full charge, so at about 42% SOC you would fall under that number with that consumption.(Some on these forums have speculated that the car was deciding to limit power based on Projected Range. I have to disagree - it's pretty clear that the limiting factor is drive train temperature. Without readouts I can't tell if it was the motor or power electronics... but you can tell by how fast it happens that it's one of the two. Based on my Roadster experience the battery pack has way too much thermal inertia for it to be the cause.)
Are you sure? Tesla has patents for liquid cooling the rotor of an AC induction motor.I think WarpedOne is referring to the rotor itself which is air cooled and not immersed in oil. The liquid cooling is a jacket around the motor.
Could both be at play? You may have hit the thermal limits, while others have not. Hard to tell right now where the limit is without battery/motor/inverter temp gauges. For the Roadster, the inverter was by far the main limiter, but the battery sometimes heats up too (charging the car heats up the battery too, so that might contribute also). The motor actually doesn't heat up that easily in the 2.0 version (with new fans).I stopped watching it long before it got that far. I was charging at 70A whenever my run group was off so it took quite a while to drop that much. Before then I was convinced that it was thermal limits. The proof was that simply pausing for a few minutes got full power back. That is consistent with the thermal limits hypothesis and inconsistent with the projected range hypothesis.
What does this desired behavior have to do with the Plus package?As part of the Performance + package Tesla should have the ability to "supercool" the pack and motor to allow for sustained fun at the track..
During autocross, my projected range got around or below 30 when I started to see the acceleration limiter.So I take it you monitored your projected range and it never fell below 30 miles or so?
I think the Model S's inverter is now liquid cooled, so it should fare better than the Roadster.
I don't own a Roadster, but in many threads I have read, the PEM overheating seems to come first and more often than the motor overheating. Maybe this is flipped on the track.Have you had your Roadster on the track? I have and can say with 100% certainty that my Roadster ( 2.0 with new fans ) was power limited because of heat in the motor and not the PEM.
I can dig up log files if necessary.
They may have patents, that does not mean they have such motors, it just means they thought about it and filed a patent.Are you sure? Tesla has patents for liquid cooling the rotor of an AC induction motor.
