Page 34 of 35 FirstFirst ... 24303132333435 LastLast
Results 331 to 340 of 350
Thread: PEM, motor gets too hot -- fans failed
  1. #331
    #421 Model S #S32 Eberhard's Avatar
    Oct 2010
    Germany
    I still face a lot of problem with overheating the PEM and reduced charging current. The reason is dirt. i got some tubes installed to make an emergency cleaning by pressured air possible. but it happened, that even my emergency plan stopped working. I had to go to the munic tesla store to get my PEM cleaned.
    the only solution beside a liquid cooled PEM is air filtering or a redirection of the cooling air from the upper air inlets instead through the wheel housing.
    With a working air filtering, the original blower combination may work as well.
    Roadster EU#421 162.900km MS Sig P85+ 148.000km
  2. #332
    Senior Member W.Petefish's Avatar
    Apr 2011
    North Texas (DFW)
    I'm with you on a liquid cooled PEM.
    If it is worth doing, it is worth OVER doing. - Mythbusters
    Arctic White Roadster 2.5 #1200, S Sig Performance Vin# 227, HAM: KF5WDB, Look for the Skywarn stickers...
  3. #333
    TMC Moderator TEG's Avatar
    Aug 2006
    Silicon Valley
    The rumor mill was buzzing about different battery packs, and motor upgrades, but nothing about PEM upgrades.
    Hopefully they do something there, but I think the odds of that happening might be a little lower than some of the other things we heard might be coming.
    Moderator - Roadster, Model 3, and Future Cars forums
  4. #334
    Lead Moderator Doug_G's Avatar
    Apr 2010
    Ottawa, Canada
    Blog Entries
    2
    Quote Originally Posted by TEG View Post
    Not quite true... the rumored motor upgrade included a PEM cooling upgrade.
    TMC Lead Moderator
    Roadster #919, Model S #2006. Blogs The Rules of Model S Road Tripping, Cold Weather Driving
    All posts are copyrighted.
  5. #335
    Senior Member hcsharp's Avatar
    Jun 2011
    Vermont
    Quote Originally Posted by Doug_G View Post
    I heard from a Tesla service manager yesterday (draw your own conclusions about accuracy) that they were trying a nitrogen gas cooling system for the PEM (lighter than liquid cooled) to go with the liquid cooled motor upgrade. He said it was a new PEM but not the same as the Model S PEM. He said they have 2 roadsters testing the system.
    But the most interesting thing he said was that they're aiming for 0-60 time of under 2.5 sec that will rival the Veyron. It included a limited slip diff and different tires. The traction control is more advanced and allows the rear wheels to slip a tiny bit because you actually get more traction that way. He also qualified it by saying nothing is finalized yet and some of what he heard may turn out to be just more rumors.
    The sad part is he thought it would probably be priced at about half of what most of us paid new for our roadsters.
  6. #336
    Nov 2011
    Long Beach, CA & Taos, NM
    Half Price?
    Quote Originally Posted by hcsharp View Post
    When I first read about a possible performance upgrade someone mentioned "pricey". I assume 50k - 75k. If everything that has been mentioned, including 2.5 second 0-60, could be purchased for $75k - I'll be one of the first. This possible upgrade is one of the few reasons I'm still working! While $75k is a lot - look at what people are paying for headlights, CF trim, sound proofing upgrades, etc.
  7. #337
    Jun 2011
    Vermont
    Quote Originally Posted by Tesla 940 View Post
    It would be out of my price range but if it truly rivals the all-wheel-drive supercars for 0-60 like the Veyron and a couple others then they will sell a lot of this upgrade. In fact I predict it will be so popular that used Roadsters will increase significantly in value as a result.
  8. #338
    Sig 100 - #52 frequencydip's Avatar
    Dec 2011
    Los Angeles
    +1 values should go up if for a used roadster and this upgrade you would have a car that can do 0-60 in 2.5 and not over heat for $140, as a track car this would dominate even 911 turbos...
    I also wonder if the upgrade would work for all roadsters, the 1.5 and 2.5 PEMs have significantly different designs. If they replace everything back there it probably doesn't matter..
    Nitrogen gas? are we talking liquid nitrogen? Can anyone theorize how nitrogen gas would be used for cooling without having to add nitrogen tanks on a periodic basis?
  9. #339
    Senior Member wycolo's Avatar
    May 2012
    WY
    > a nitrogen gas cooling system for the PEM (lighter than liquid cooled) to go with the liquid cooled motor upgrade. He said it was a new PEM but not the same as the Model S PEM. He said they have 2 roadsters testing the system. [hcsharp]
    They would have to stuff a heat exchanger (N>coolant) under the hood or somewhere. It could be linear and even flexible. Without taking the PEM apart it could be placed in a sealed bag and N blown thru it. If pressurized a bit it would help cooling at high altitudes where we now take a hit. Even N cools better under increased pressure. Looks like a 'tire' could be clamped over the motor and N blown thru. Do we see the possibility of a low-cost DIY Nitrogen upgrade in the works here?
  10. #340
    Senior Member strider's Avatar
    Oct 2010
    Bay Area, CA
    That's a fair price for those specs. It's something I would look to do in a few years - I normally get the itch for a new car every 5 years so in this case I could do the upgrade in lieu of a new car.
    Twilight Blue Roadster 2.5 - #1098 / Grey Model S Performance - #1459
  1. PEM Failure
    By tdevince in forum Roadster: Technical
    Last Post: Yesterday, 10:21 PM
  2. PEM Temp Readings
    By Aspirant in forum Roadster: Technical
    Last Post: 2013-10-06, 08:22 AM
  3. Take THAT, Tesla fans!
    By dpeilow in forum Off Topic
    Last Post: 2013-09-10, 01:36 PM
  4. Universal Mobile Connector - failed
    By harbthom in forum Roadster
    Last Post: 2012-07-11, 11:47 AM
