Re: Turn signals. I actually broke down and RTFM last night. Practiced in my garage where I could see what was happening while sitting in the drivers seat. It's better and worse than I thought.
Better: I was under the impression that there were two modes. A quick one that will turn off automatically, and the long one that will only turn off after you make a turn and return the yoke to the center position. That's not the case. Nor is it the case that "it should be three blinks instead of 1." As it turns out, there are simply two ways to invoke the turn signal. A "light" press which will continue to signal until you release the pressure (this gives a single haptic feedback vibration) and a "harder" press which will immediately go into the "long" mode (which gives a double vibration). This means that you really can (with a deft, light touch) signal a few times to change lanes without needing to turn it off again. I really think I *can* get the hang of this to the point where it will be quick and easy to get it right. Especially after practicing a bit more where I can see the results.
Worse: The haptic feedback occurs well before the signal actually flashes! This means that a quick light touch, which rewards you with some feedback is *NOT* enough to signal your intentions. You *must* keep that touch for as long as it takes for the signal to activate. This is approximately a full second. Practice where you can see it, and you'll get the hang of it, but I really wish that activation at least guaranteed a single flash of the turn signal! In the end, I hope this is more of a feature than a bug in that quick accidental swipes while adjusting the volume wont make you look like an idiot to the cars behind you, and typically you want to hold lightly for 3 or so flashes anyway to indicate your intentions. This will take some time to get used to.
