I know it's all under warranty, but that much trouble in a year is disconcerting. One of the attractions of the EV for me was higher reliability and less failures. Granted, the Roadster is Tesla's first car where lessons are being learned, but still worrisome. I need the Model S maintenance/repair rate to be low over a very long life to help justify it's expense.
Not wanting to get too off topic here, but to answer your concerns: As I see it, I've had three main issues in the year:
(1) A faulty VMS. This was just plain faulty and since it was swapped has been very reliable.
(2) A faulty PEM. Something shorted inside (presumably a component failed), and blew a fuse, that also blew an upstream fuse in the battery.
(3) A problem with high humidity and the orange 400V power converter in the front of the car. This has blown a couple of times for me - one time it also blew an upstream fuse in the battery.
The battery itself has been fine both times - it is just the high power fuses are inside the battery housing itself and that is a major undertaking to get out of the car and service.
(1) and (2) are just straight electronics failures. I hope that Tesla can improve the reliability of these sorts of components, given the greater quantities of Models S and X.
(3) is something inherent to high-humidity environments. Tesla are supposedly working on sourcing a replacement part that doesn't suffer from this problem.
There is another known problem of the fans failing (which I guess is the original problem reported by Eberhard here). Similar to (3), this is a problem in snowy/wet environments that we haven't seen in Hong Kong.
Tesla service, in all cases, has been nothing short of amazing. The only thing I would ask for, that they don't provide, is a loaner car.
The Roadster is a proving ground for a lot of this technology, and constrained by the Lotus arrangement. I really hope that Tesla have learned what not to do for the Models S and X. It seems that, at least from the battery management point of view, they have improved the vampire drain levels compared to the Roadster (although, in my opinion, it makes little practical difference). Battery swap is also supposedly down to a few minutes (vs 3 days for a Roadster).
