cantdecide
My wish list had something that was much more advanced than what others here wanted...
The car already has a way to convert 110v to batter voltage, and also 220V40Amp to batter voltage... the charger... can this be run in reverse?
What I wanted to see is a 14-50 220volt outlet (as well as 110volt outlet) on the back to plug a travel trailer into. Use cases:
1) towing a travel trailer... now I can run the trailer's refrigerator without needing to use propane [greenhouse gases etc]. Also when I get near my destination, turn on the AC in the trailer.
2) At an RV park with a 14-50 outlet... plug the car into the outlet, and the trailer into the car. Depending on AC etc trailer varies between 5amp and 40amp drawing... the car grabs the other 0-35amps to charge the car. By the end of the night the car is full and I've had all the power I want in the trailer.
3) Visiting a friend/relative for a reunion... park in the backyard, but they only have a 110volt outlet. Plug the trailer into the car and the car into the outlet. Now I get 220volt in the trailer to run everything, but average under 1000watts so the car net gains range also.
4) Friend comes over in a model S and we both want to charge overnight from a single 14-50... Daisy chain them instead of setting the alarm for 2am to switch them over. When we get our X we will have S,X,i3,leaf but only two 220volt charging capabilities.
The above is just somthing that makes full use of the car being electric, it is not something any gas SUV can do. Maybe next year's X will have it...
