It's very important to always check the SC connector before you plug it in. I've seen at least one that had damage and reported it to Tesla.
I also always blow in there in case there is any dirt.
Keep in mind, there are plenty of Tesla-hating *******s that love to sabotage the SC's out there! Sad but true. If someone jams something in there and you plug it into your car, it could also damage your inlet, as well as leaving you now stranded.
LOOK before PLUG! =)
Also, if you find one damaged, please tape it off or otherwise try to label it so someone else doesn't fall victim. It's doubtful Tesla can get to it very fast.
Hi guys. I seem to have my charging problems in Vacaville. I am the one with the white smoke last Xmas that Tesla never found a reason for. This time, I was charging at 100 kW when the current suddenly dropped to zero. When I checked the supercharger cable, it was almost too hot to touch. On removing the cable, there was clear sticky stuff oozing out the end. Luckily, I had enough charge to get home to east bay. The chargers on either side in Vacaville would not connect. (yellow error no matter how many times I replugged). Perhaps my inlet was gooed? At home my J1772 worked at 30 amps/240v through the adapter. I had planned to test the car at Fremont, but Tesla was concerned I might burn up another SC. Tesla checked the car and said the on board charger was fine. (I thought they weren't used with supercharging?). They replaced the inlet., said they checked supercharging at San Rafael. I hope that it works, since I have a trip to Madera on Saturday that will need a charge in Manteca. Below is a picture. Anyone else seen this?p.s. No more white smoke in 20k miles.
I disagree. They are very very fast, especially with safety issues.Also, if you find one damaged, please tape it off or otherwise try to label it so someone else doesn't fall victim. It's doubtful Tesla can get to it very fast.
Ok, they may be fast, but it's still possible that someone could pull in after you and receive damage, so let's agree that marking the damaged port is a good idea, ok?I disagree. They are very very fast, especially with safety issues.
Example, sinkhole started forming at the Madison Supercharger under 1A. Called on a Sunday Night, LATE. Maybe 11pm. Drove back through EARLY Tuesday morning, it had already been excavated, concreted in and coned off.
Not wanting to rehash old news, but 1) you earlier said you did have after-market wiring in the area where there was white smoke
Jeeze, I think he just made that reference to re-introduce himself... not to suggest there was any correlation between these two events.
Oh of course, I was not disagreeing with that. Wisconsin is a bit different, our stations are not heavily utilized, rare we see another car charging Accept at Madison, as that's the east west hub yet at the moment, mostly un-skippable and only 3 stalls....Ok, they may be fast, but it's still possible that someone could pull in after you and receive damage, so let's agree that marking the damaged port is a good idea, ok?
