I'm not sure by JdeMO you mean the part on the car or the charger.
If you mean the charger that is not true. While the car does transfer battery parameters to the charger first to ensure compatibility, once the charge session starts the BMS on the vehicle controls the entire process (including cell / pack conditions). The charger itself only monitors the signal that the vehicle uses to command it (basically current).
https://code.google.com/p/open-chademo/
If you mean the JdeMO equipment installed in the car, that may be true. It might not be the Roadster BMS doing the job.
I think we're confusing elements of how this has to work. The CHAdeMO charger is just that... an off-board charger. This JdeMO equipment is somewhere between the battery and the charger. The vehicle BMS is programmed to control up to 70 amp / 240 volt AC charging (16.8kW / 42 to 56 amps DC at battery voltage from the Roadster onboard charger or three phase motor, depending on which Roadster model), in addition to its many other functions.
I can't imagine that the Tesla firmware is modified to now provide the ability to detect DC charging (which CHAdeMO does not send, unlike CCS / Supercharger which sends a signal of "less than 6 amp", signifying digital communication), in addition to modifying the Tesla BMS power settings (at least 125 amps DC, up to 200 amps DC). I'm sure there are other things I'm overlooking.
It was stated up thread that the RAV4 EV version was parasitical, so it doesn't seem logical that this version for the Roadster would be a different design, correct? In the grand scheme of things, a 400 volt battery is just that. But, as we know from the Tesla CHAdeMO adapter, there must be some basic suite of hardware, including relays.
It sounds like that hardware goes in the boot, which means that the actual inlet could likely go anywhere with enough cable between the hardware / relays and the CHAdeMO inlet. The other end of the hardware would be connected to the battery somehow. That hardware, if operating as a parasite, must be fully capable of controlling both the CHAdeMO charger and adjusting the charge rate by whatever the BMS is reporting concerning the battery parameters.
If if there were no BMS interaction, clearly this could still charge the battery, albeit without the protections of exceeding any limit of the battery. So, my conclusion is that the BMS on the Roadster will be "along for the ride", and not controlling anything except its normal duties of cell balancing, protection from bricking, and blindly reporting all the data that we already know (from service center screen shots) that it reports... pack and cell voltage, temperature, etc.
What more would any off-board charger need to properly charge the battery? By your link, the SINGULAR most important piece of information the off-board charger needs is "how many amps?". It appears any external hardware can provide this information to the charger with the data derived from BMS reporting.
- - - Updated - - -
I drove my new Leaf from San Jose to Sacramento and back with only a short stop in Sacramento. On the way I charged ChaDEMO twice back to back and on the way back I had to charge twice again. I lost a full capacity bar on the Leaf that day. I ended up filing a complaint with Nissan and they attributed it to the ChaDEMO.
This seems to be an "open and shut case". Clearly CHAdeMO destroys batteries after just a couple uses. I recommend switching to Superchargers... just trade that LEAF in and get a shiny new Model S, Model X, or in a few years, Model 3.
