just-an-allusion
Banned
My question, of course, is "why batteries are needed at all?"
Yep, adding lightness helps everything. Probably another 20 miles or so. The only downside is cost.
Cost of the materials, certainly - but for anything non-track related, possibly cost in re-crash testings. which is mega-expensive. Since (to our knowledge) they have not started crashing the Model S, there is still a chance for that. But I can't imagine them doing more design work on the Roadster in the near future.
Since there are lots of similarities between the Roadster and the Model S drive train (supposedly) it is possible they could pioneer it with the S and back-port it to the Roadster at some later date.
Trust me, DC-DC boost buck power supplies aren't that difficult. The prius has one right now...
Yes! More options would be better for everyone!
However, as dpeilow pointed out a significant shift in battery weight may require new crash testing - which I can't see Tesla doing in the near term. That could be ignored for a track car, though...
Which brings me back to my original statement that the easiest way to double track range(test gear style track) would be to swap to 2900mah cells and include a cap pack to capture regen.
How do you figure? High speeds and hard acceleration takes more energy, no matter what the power plant. No amount of regen will recover energy lost to wind resistance and ground friction, and regen strong enough to lock the rear wheels won't help anything. There is no practical or reasonable use for ultracaps in the Roadster.I guess it just irks me, because I know that this is one area where the Tesla should excel at since an electric powertrain is not inherently less efficient when driven like Top Gear did than when you drive it like a Prius. Its just a design issue. Which is a huge differentiator between BEVs and IC cars.
...There is no practical or reasonable use for ultracaps in the Roadster...
Since the addition of caps would increase the price, I don't see that as a practical use. Also for the average driver I don't see the pack as being stressed that much without caps, so they would provide even less value. I suppose at some point the price of caps and the cost of integrating them into the pack could be low enough that they might provide a real world benefit but I don't think we are even close to that.To make the battery pack last longer?
(Although I suppose the calendar lifespan of the pack could run out before you hit the expected 500 cycle lifespan).
I think even with an electric motor hard acceleration will draw more amperage, which means more heat build up, which means less efficiency. A vehicle will slow down even without braking or regen because of drive train and road friction as well as wind resistance, you can't recover that energy. Hard cornering will also slow you down without braking, because of friction, which is also lost energy you can't recover.
As for real world hard acceleration affecting range, caps won't help much since most people will accelerate hard to show off the power, or just for the fun of it, but then don't slam on the brakes immediately after. They coast or level off and continue traveling. So I only see caps helping if someone repeatedly slams the throttle and then slams the brakes, which is basically racing, and not what the Tesla is made for.
First of all it is 6831! All true Roadster fans have that number memorized.
:smile:
Two things.
My wife is now quoting that number in the middle of my EV stump speech at parties. She is so proud of herself.
Chelsa said in a recent talk that all the engineers in Detroit know that number. They may not talk about Tesla much but they are paying attention.
You trying to make me feel bad :frown:
