Let's get real, here.
Take an ICE. One is literally burning hydrocarbons. The inside of the cylinder wall gets, no kidding,
hot. As in, blisters on your fingers hot. I mean, this is hot exhaust on the inside of the cylinder. Yeah, the block is water-cooled; that still doesn't stop the cylinder walls from betting 'way up there.
Next: Each piston has metal rings around said piston. These suckers
slide up and down the cylinder. In general, lubricants work on a near-microscopic level by separating two pieces of metal with a thin film of lubricant.
The engine literally sprays oil on the cylinder walls. Some of that lubricant is going into the combustion chamber and is, inevitably, going to end up being wiped back into the main reservoir of oil in the crankcase. Further, high-pressure, high-temperature gases are going to leak out of the combustion area down past the rings. All of this is subjecting the oil to high temperatures.
What happens?
- The oil molecules literally break into smaller pieces. Smaller pieces don't lubricate so well.
- Highly acidic combustion products, carbon particulate matter, and combustion by-products (CO, CO2, H2O, carbonic acid, and whatever happens to all those chemicals they put into gasoline so it "burns smooth" when they combust) end up in the oil. There's REASONS oil turns black, and that's it. All that junk also degrades the oil and makes it not lubricate well.
- Most ICE engines run near, at, or above the boiling point of water. That's hot. The Arrhenius equation says that chemical reactions (as in, breaking down stuff like oil) goes as the exponent of the absolute temperature.
Back in the really long ago, engine oil had to be replaced every 3000 miles. It's a major miracle of automotive and chemical engineering that we can take refined dino juice and get it to last 10,000 miles.
So, let's look at a Tesla BEV. Um.
Nothing is running near the boiling point of water. There's
no exhaust gases, anywhere.
The coolant is, as far as I know, similar to ICE transmission fluid: It's got lubricant built in (like a thin oil). Think about it: Transmission fluid in ICEs gets replaced, what, every 45,000 miles or something? But let's get real again. In a true-blue automatic transmission there are, yes, gears. Just like a Tesla. But there also happens to be a torque converter where, by gum, a ton of sheer stress is put on the transmission fluid. Further, there a little bitty clutches that open and shut, sliding madly against each other, adding more sheer stress to the fluid.
How often is transmission fluid in an automatic changed? I think we're talking 45,000 miles or so.
Now, Teslas. The coolant is pushed through the battery and motor assembly for coolant purposes. Nothing is as hot as an ICE.
Let's look at the oil in the electric motor. Which is cooled by ye fluid and runs nowhere near as hot as an ICE. The closest thing I've ever messed with that looks like this was the manual transmission on my old '71 VW Beetle. Hypoid gear oil Changed: Once every 90,000 miles, if memory serves.
And, even with this: A VW Beetle's transmission has synchronizers so one doesn't have to double-clutch. Those synchronizers are, effectively, clutches and do put high pressure on the oil when one shifted gears.
That lasted 90k miles. The transmission in Teslas is nowhere near as complex: It's
one speed. Admittedly the reduction gears and the differential share the same oil, I think.. but it's lot less intense in there compared to a old-time manual transmission with tons of gears and synchronizers.
What Tesla says:
- Battery Coolant is Life of Vehicle.
- Electric motor oil: They don't even mention it.
And, on that oil: I've overhauled ICE engines. After an overhaul, with resurfaced cylinder walls, new rings, new bearings, and all that jazz, one expects some wear. So, responsible types usually change the oil after the break-in interval where all sorts of metallic particles have been ground off this and that and deposited in the oil, then run through the filter. The break-in interval is, what, 500 to 1000 miles or so..
After that - one needs the filter to snag all that carbon and tar and shellac from the combustion process. None of which a Tesla has.
So the filter in a Tesla is around to catch the initial bit of metal particles as the gears wear into each other. After that - no more garbage. And no need to change the filter.
Next question?
